Hello awesome community, I trying change to bspwm, and I wanna set my resolution and scale like my kde settings. Its really important for me set scale because without that i can't see my monitor well. Also I tried set global scale with xrandr --scale, but results are a bit blurry
Sara Afriland
Try re-selecting 1920x1080.
Sometimes, particularly on a new install, it will do the same--blur--on my single desktop monitor. Re-selecting the (same) resolution fixes it (on mine).
regards
Yes I tried multiple times and don't works, the screen is blurry with scale, without scale looks so little.
Post output of xrandr. There we can see available resolutions, and sizes of your displays, and adjust resolution and scale of each so physically in real life the sizes of windows are relatively similar and it looks sharp.
