How on Earth do I get rid of the Remote Control Requested Pop Up Box?
Hey folks, I’ve been using Garuda Dragonized for about a year now and there’s one quirk that I absolutely cannot stand and was wondering if there was some help you guys could provide. Whenever I nudge my controllers joystick or something similar when I’m not in a game, KDE forcibly takes control of my active window with the remote control request pop up. I straight up cannot upload an image of it but I’m sure most of you are familiar with it. It hasn’t been too big of an issue but I’m running into an issue where it’s ignoring my game now and asks for permission to take control even when it shouldn’t. Is there a way to just straight up get rid of it as an application? I literally never use this feature and it’s just obnoxious at this point. I’ve tried and tried to find someone with a similar issue but nothing has provided a solution. Here’s INXI I guess? Not sure if this’ll help but forum rules.
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cba56c69-0edd-4f79-86f2-4bea67f25e09 rw rootflags=subvol=@
quiet resume=UUID=911d62b3-5d1b-4874-89b2-696992aa4428 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Mobo: ASUSTeK model: PRIME B450M-A II v: Rev X.0x
BIOS: American Megatrends v: 4202 date: 06/16/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4386 min/max: 550/4654 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4386 2: 4386 3: 4386
4: 4386 5: 4386 6: 4386 7: 4386 8: 4386 9: 4386 10: 4386 11: 4386 12: 4386
bogomips: 88803
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Tul / PowerColor driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0 chip-ID: 1002:73df
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: primary,top-left model: Sceptre Y27 serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 165 scale: 125% (1.25) to: 2048x1152
dpi: 108 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: DP-3 pos: bottom-r model: Acer XF273 S serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
navi22 LLVM 19.1.7 DRM 3.61 6.14.2-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Blue Microphones
lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 046d:0ab7 class-ID: 0300
Device-4: Intel USB2.0 Device driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:5
chip-ID: 8087:1024 class-ID: 0300 serial: <filter>
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
IF: wlp7s0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0032
Local Storage: total: 2.37 TiB used: 1.38 TiB (58.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 45.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: J4.3 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2BP240G4
tech: SSD serial: <filter> fw-rev: 0420 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SV300S37A120G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: MBR
ID-1: / raw-size: 206.53 GiB size: 206.53 GiB (100.00%)
used: 170.65 GiB (82.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 206.53 GiB size: 206.53 GiB (100.00%)
ID-3: /var/log raw-size: 206.53 GiB size: 206.53 GiB (100.00%)
ID-4: /var/tmp raw-size: 206.53 GiB size: 206.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.49 GiB used: 844.9 MiB (5.3%)
ID-2: swap-2 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 62.5 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1258
Memory: total: 16 GiB available: 15.49 GiB used: 7.09 GiB (45.8%)
Processes: 414 Power: uptime: 6h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: 1898 pm: pacman pkgs: 1893 libs: 575 tools: octopi,pamac,paru
pm: flatpak pkgs: 5 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date:     2024-10-09
Last full system update: 2025-04-16 ↻
Relevant software:       timeshift NetworkManager dracut
I’m going to be blunt you’re requesting help don’t WHINE about being asked to post your garuda-inxi. You’re the second person in two days to do so, just DON’T.
This is a well-known KDE bug that has only been partially fixed - the main cause is Wayland’s security architecture. A workaround is to use x11 instead of Wayland. You can switch between an x11 and a wayland session on the login screen.
btw:
a reboot is pending after a system update.
did i say “ugh god INXI?” just didnt want to look like an idiot if the question didnt need it.
gotcha, thank you!
