inxi
output
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=179b848a-d752-453c-8e55-0fb01cf9d4e7 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP Compaq 6720s v: F.0A serial: <filter> Chassis: type: 10
Mobo: Hewlett-Packard model: 30D8 v: KBC Version 83.0E serial: <filter> BIOS: Hewlett-Packard
v: 68MDU Ver. F.0A date: 04/14/2008
Battery: ID-1: C23B charge: 46.0 Wh (100.0%) condition: 46.0/46.0 Wh (100.0%) volts: 12.5 min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core2 Duo T5670 bits: 64 type: MCP arch: Core Merom family: 6 model-id: F (15)
stepping: D (13) microcode: A4 cache: L2: 2 MiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7182
Speed: 1796 MHz min/max: 800/1801 MHz boost: enabled Core speeds (MHz): 1: 1796 2: 1953
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Mobile GME965/GLE960 Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:2a12 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1280x800 s-dpi: 99 s-size: 330x210mm (13.0x8.3") s-diag: 391mm (15.4")
Monitor-1: LVDS1 res: 1280x800 hz: 60 dpi: 99 size: 330x210mm (13.0x8.3") diag: 391mm (15.4")
OpenGL: renderer: Mesa DRI Intel 965GME/GLE (CL) v: 2.1 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel 82801H HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:284b class-ID: 0403
Device-2: Texas Instruments PCM2906B Audio CODEC type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 4-1:5 chip-ID: 08bb:29b6 class-ID: 0300
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Intel 82562GT 10/100 Network vendor: Hewlett-Packard driver: e1000e v: kernel port: 4020
bus-ID: 00:19.0 chip-ID: 8086:10c4 class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu bus-ID: 2-2:2
chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: wlp0s29f7u2 state: up mac: <filter>
Bluetooth: Device-1: HP Bluetooth 2.0 Interface [Broadcom BCM2045] type: USB driver: btusb v: 0.8 bus-ID: 3-1:14
chip-ID: 03f0:171d class-ID: fe01
Report: bt-adapter ID: hci1 rfk-id: 20 state: up address: <filter>
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 5-1:5
Report: ID: hci0 rfk-id: 19 state: up address: N/A
Drives: Local Storage: total: 111.79 GiB used: 16.27 GiB (14.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: SSD2SC120G1CS1754D117-551 size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 1101 scheme: MBR
Partition: ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%) used: 16.27 GiB (14.6%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%) used: 16.27 GiB (14.6%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%) used: 16.27 GiB (14.6%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%) used: 16.27 GiB (14.6%) fs: btrfs
ID-1: swap-1 type: zram size: 3.83 GiB used: 254 MiB (6.5%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 50.0 C mobo: 24.2 C
Info: Processes: 198 Uptime: 3d 16h 41m wakeups: 25 Memory: 3.83 GiB used: 2.41 GiB (63.1%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1307 lib: 317 Shell: fish v: 3.3.1
default: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
I host a radio program and produce it from my above shown laptop. As you can see, only the internal audio device is showing up, not the USB sound card I have plugged in. See Bus 4, Device 5 in lsusb
output:
Bus 002 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 005: ID 08bb:29b6 Texas Instruments PCM2906B Audio CODEC
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 014: ID 03f0:171d HP, Inc Bluetooth 2.0 Interface [Broadcom BCM2045]
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
(yes, you read that right -- USB 3.0 in a laptop made in 2009)
pactl list sinks
also shows only the internal sound card. Because I was 30 seconds from going live and needing to play audio from my laptop, I tried to just restart pulseaudio, I tried to log out and log back in. I didn't have time for a full reboot. The pulseaudio
command was not found. Logging out didn't fix it.
I wound up physically moving the laptop over to a different part of the studio where I could plug in a headphone jack, where it was difficult to reach and I had to lean away from the mic to get to it. Ah, the joys of hosting a radio broadcast, especially on an ancient laptop running a rolling-release distro!
Writing this up, I think I know why my device wasn't detected -- I updated the machine the morning of the show and didn't reboot. plasma-pa
was in the update list, so it makes sense. (I wouldn't normally have done that, but I needed to install...something, my package lists were out of date, you're not supposed to run -Sy
and not -Syu
, blah, blah, blah). So I suppose my question comes down to
How is my audio managed by Pulse audio if
pulseaudio
isn't installed? How do I restart it?
Is pulse managed by pipewire now?
