I just wanted to create some for those apps not having the icons
Create a .svg file and create a merge request.
(And don't forget to save with correct filename. )
Many apps may just need a symlink for already existing icon. Before creating a new one check if already an icon suites the app and symlink with proper filename.
how to check which file name is correct?
What should I use gimp or blender? I am learning them from scratch
Gimp is for 2D raster art. Blender is commonly use for 3d Art. So, whatever suits you?
There are a lot of other options too, but I would suggest GIMP or Krita to begin with.
Just keep the same name as desktop app name. See usr/share/applications
It might take days, I am just trying
