I want to reset the system back to its default with all the apps uninstall
Reinstall.
And
Simplest way is reinstalling. Because if you remove kde settings, it will give you stock kde and will remove Garuda themes and defaults.
So, reinstalling is best solution, as already mentioned by TBG.
