How do I use `yay` from bash?
I had to use bash in order to install some application, but when I used yay, I got this error:
bash: yay: command not found
System Info:
Kernel: 6.8.9-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=a3ed4574-408f-4802-8fc7-dded1b46b1ac rw rootflags=subvol=@
resume=UUID=21ea485a-d6f1-4646-b304-bca6967a48e0 loglevel=3
mitigations=off ibt=off
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QM.331
date: 02/24/2023
ID-1: BAT0 charge: 50.9 Wh (60.0%) condition: 84.9/90.0 Wh (94.3%)
volts: 15.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 714 high: 2395 min/max: 400/4463 scaling:
4: 400 5: 1916 6: 400 7: 400 8: 400 9: 1916 10: 400 11: 2395 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 102267
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 46.0 C
compositor: kwin_wayland driver: X: loaded: modesetting dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 1920x1200 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
renoir LLVM 17.0.6 DRM 3.57 6.8.9-AMD-znver3) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.6-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.8.9-AMD-znver3 status: kernel-api with: aoss
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Local Storage: total: 2.77 TiB used: 1.22 TiB (44.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 159.89 GiB (32.0%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 500 GiB size: 500 GiB (100.00%)
used: 159.89 GiB (32.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:7
ID-2: swap-2 type: zram size: 30.79 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
Memory: total: 32 GiB note: est. available: 30.79 GiB used: 4.2 GiB (13.6%)
Processes: 375 Power: uptime: 16m states: freeze,mem,disk suspend: s2idle
image: 12.28 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2293 pm: pacman pkgs: 2280 libs: 593 tools: octopi,paru
pm: flatpak pkgs: 13 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-03-16
Last full system update: 2024-05-11 ↻
Windows dual boot:       YES
Use paru , or install yay.
you have to install yay for each shell? Because it’s already installed for fish
Thats an alias for Paru. Maybe we should align the configs to behave the same way for bash and fish.
