How do I switch from Wayland to X11?
How Do I switch from Wayland to X11? My system keeps crashing after update. I suspect the cause of this to be Wayland.
I can switch to X11 at the log in screen at the bottom left corner.
ya at the login screen. I had weird issues on Wayland with NVidia so went right back to X11 pretty quick
I want to note: Wayland on Fedora is working perfectly fine for me so far. (and X11 is extremely laggy and non-usable, so reverting to it won’t be an option)
When I tried in Garuda, I got stuck at MPV running upscaling shaders that caused an error. Now that’s running fine. Not sure what’s the difference between Garuda or Fedora here.
Time will tell if I run into issues later.
