How do I speed up animations in Latte Dock when minimizing and restoring minimized windows?
I tried changing the animation speed in the panel under edit panel > effects > animations are still the same speed.
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=22e89400-028c-4ff2-a8ff-4906ac02b6c9 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <superuser required>
BIOS: American Megatrends v: P5.10 date: 05/06/2021
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 70%
rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2926 high: 3081 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2080 2: 3081
3: 2902 4: 3072 5: 3069 6: 3079 7: 3070 8: 3058 bogomips: 59197
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: PNY driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4.3:4 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: PNY
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 717.99 GiB used: 19.37 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: HP model: SSD S700 500GB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4A1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G
type: SSD serial: <filter> rev: 71E0 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 19.37 GiB (17.3%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 57 C
Processes: 277 Uptime: 59m wakeups: 6 Memory: 15.54 GiB
used: 3.51 GiB (22.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1828 lib: 542 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-26
Last full system update: 2022-03-29
