ThinkPad T450 laptop
I can change the brightness with command echo 2 | sudo tee /sys/class/backlight/intel_backlight/brightness
The default increment in garuda when using the brightness key is 5% or increments of 50, and I want to change the increment to 2 instead.
Is there a way to change the brightness increments when using the brightness keys?
Keyboard media key function is typically set up by the hardware manufacturer, in a way that interfaces with firmware. The function of these keys is not really up to Garuda, or any OS for that matter.
Sometimes a manufacturer will incorporate a user-accessible interface for exposing or manipulating these firmware components so custom key mappings, etc can be set (this is a feature of System76 hardware, for example), but that is uncommon. Typically you get what you get.
Regarding your specific hardware (or perhaps a similar model), Lenovo Community Senior Mod Rich says (essentially) no, you can't change this: English Community-Lenovo Community
Your best bet will be to write up a script changing the brightness with the terminal-accessible settings you mentioned, and assign the functions of the script to custom keyboard shortcuts.
I have to disagree that the increment is up to the hardware.
On vanilla arch using the i3 desktop environment, I could use the /etc/i3/config file to change the keyboard configuration and rebind the brightness keys to run brightnssctl. So I'm pretty sure its not something thats hard coded into the laptop, or at least I know it can be reconfigured.
I'm gonna have to try using something like xbindkeys, but what ever method garuda uses seems to override thebrightnessctl command.
ArchWiki / KeyboardShortcuts
I was hoping garuda had a similar kind of config file or some easy way to reconfigure this setting. The appeal of Arch is supposed to be is supposed to be highly configurable. If the desktop environment gets in the way of this then that is disappointing.
SGS
18 October 2022 13:31
4
Missing your garuda-inxi.
# garuda-inxi --help
Kernel: 6.0.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=952eaeec-7025-4a75-845b-9396911526a6 rw rootflags=subvol=@
resume=UUID=fdc5ecaf-2802-4a71-9089-200bfcfa40a3 loglevel=3
mitigations=off sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20BU000AUS v: ThinkPad T450
Mobo: LENOVO model: 20BU000AUS v: SDK0E50510 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: JBET73WW (1.37 )
date: 08/14/2019
ID-1: BAT0 charge: 17.2 Wh (97.7%) condition: 17.6/23.5 Wh (75.0%)
volts: 12.4 min: 11.4 model: LGC 45N1113 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 18.4 Wh (100.0%) condition: 18.4/23.2 Wh (79.1%)
volts: 12.3 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2694 min/max: 500/2900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2694 2: 2694 3: 2694 4: 2694 bogomips: 18359
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable
Type: tsx_async_abort status: Vulnerable
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-8:4 chip-ID: 04ca:703c class-ID: 0e02
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: AU Optronics 0x303e built: 2012 res: 1600x900
hz: 60 dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
Sound API: ALSA v: k6.0.1-zen1-1-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
IF: wlan0 state: up mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 2-7:3 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
Local Storage: total: 238.47 GiB used: 108.08 GiB (45.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State
Disk size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 91.3 scheme: MBR
ID-1: / raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 108.08 GiB
(47.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 108.08
GiB (47.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 108.08
ID-4: /var/tmp raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 108.08
ID-1: swap-1 type: zram size: 7.47 GiB used: 2.68 GiB (35.9%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 74.0 C pch: 59.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4034
Processes: 256 Uptime: 4d 10h 24m wakeups: 4 Memory: 7.47 GiB used: 3.81
GiB (51.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1929
libs: 384 tools: aura,octopi,paru Shell: fish v: 3.5.1 running-in: tilix
inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-04
Last full system update: 2022-10-18 ↻
Failed units: archlinux-keyring-wkd-sync.service systemd-networkd-wait-online.service
You are conflating the distribution with the desktop environment. Garuda offers an i3 spin as well, where my guess is you would find a familiar set of configuration options. KDE is completely different, and becoming familiar with the nuances of its configuration is not trivial.
I don’t know the mechanism behind this, but my guess would be udev . You could set up your own udev rule to accomplish this if you like, to override whatever the defaults are.
Your impression that Garuda has established a setting somewhere that determines what effect your media keys should have is incorrect.
