How do I get StarUML on Garuda? The website shows .deb and .rpm download options.
Which should I download? If not them, where do I download a package for Garuda?
inxi:
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=c877fe9c-cef9-4c56-9812-62dcfec9364d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 21JRS00U00 v: ThinkPad E14 Gen 5
Mobo: LENOVO model: 21JRS00U00 v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R2CET32W (1.14) date: 11/27/2023
ID-1: BAT0 charge: 35.4 Wh (74.8%) condition: 47.3/47.0 Wh (100.7%)
power: 12.9 W volts: 11.7 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly
serial: <filter> status: discharging cycles: 26
Info: model: AMD Ryzen 5 7530U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2040 high: 4028 min/max: 400/4546 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2516 2: 1397 3: 2401
4: 4028 5: 1397 6: 400 7: 2255 8: 1396 9: 3323 10: 1397 11: 3578 12: 400
bogomips: 47912
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 52.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b7ba
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.2-arch1.2
renoir LLVM 16.0.6 DRM 3.54 6.6.10-zen1-1-zen) device-ID: 1002:15e7
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.2-arch1.2
device-ID: 1002:15e7 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 39.65 GiB (8.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQMQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73116101 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
used: 39.62 GiB (16.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.4 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-4: /var/log raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-5: /var/tmp raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): fan-1: 2200 fan-2: 2200
Processes: 346 Uptime: 1h 21m wakeups: 1 Memory: total: 16 GiB note: est.
available: 14.46 GiB used: 4.64 GiB (32.1%) Init: systemd v: 255
pm: pacman pkgs: 1338 libs: 402 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date: 2024-01-06
Last full system update: 2024-01-24
