There is no conky folder. Should I make it ?
Nope, no point if its not there. No idea how the default templates disappeared. I guess you could look on Gitlab for the source files. Otherwise there is lots of people who post their versions online.
Did you try unhiding hidden folder?
Every folder with . In beginning is hidden by default.
In the beginning every Garuda DE has a conky file or two, but times changed it
Well its possible that its not included by default (dr460nized for example doesnt have it, GNOME too)
But its easy to install. There is a wiki entry dedicated to conky with the default config.
Its too bloated to let in skel? 5.4 KiB
So which conky is there on my screen when I run Conky ? weird..hehe
Conky standard. White letters. No transparency black background.
Garuda conky.conf
conky.config = {
background = true,
update_interval = 1,
cpu_avg_samples = 2,
net_avg_samples = 2,
temperature_unit = 'celsius',
if_up_strictness = 'address',
double_buffer = true,
no_buffers = true,
text_buffer_size = 2048,
own_window = true,
own_window_class = 'conky',
own_window_type = 'override',
own_window_hints = 'undecorated,sticky,skip_taskbar,skip_pager,below',
--own_window_colour = '#555555',
own_window_transparent = true,
own_window_argb_visual = true,
own_window_argb_value = 0,
draw_shades = false,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
alignment = 'top_left',
gap_x = 50,
gap_y = 40,
minimum_width = 400,
minimum_height = 700,
maximum_width = 420,
border_inner_margin = 0,
border_outer_margin = 20,
--xinerama_head = 0,
override_utf8_locale = true,
use_xft = true,
font = 'monospace:size=9',
xftalpha = 0.8,
uppercase = false,
-- Defining colors
default_color = '#FFFFFF',
-- Shades of Gray
color1 = '#DDDDDD',
color2 = '#AAAAAA',
color3 = '#FFFFFF',
color4 = '#808080',
color5 = '#EF5A29',
color6 = '#b2c8d8',
color7 = '#b2c8d8',
color8 = '#697987',
color9 = '#2d3b41',
conky.text = [[
# focused_workspace background #16a085 to #5D7B86
# border backgr. text
# focused_workspace #F9FAF9 #16a085 #292F34
${image /usr/share/icons/garuda/garuda-white.png -p 10,0 -s 78x59 -f 5}${font sans mono:size=10}${alignr}${color6}${alignc}
${alignr}${font sans mono:size=20}${color1}${time %r}${color}
${alignr}${font sans mono:size=12}${color1}${time %a %d-%b-%Y}${color}
${color1} ${font}
${alignr}${color3}${color}
${goto 12}+-----------------------------------------------------------+
${goto 12}${color1}+----System ${color}
${goto 15}|${goto 40}|
${goto 15}|${goto 38}+-- ${color3}Os:${alignr}${color6}${execi 130000 awk -F= '/DESCRIPTION=/{print $2}' /etc/lsb-release}${color}
${goto 15}|${goto 38}+-- ${color3}Kernel:${alignr}${color6}${kernel}${color}
${goto 15}|${goto 38}+-- ${color3}User:${alignr}${color6}${execi 11003 whoami}${color}
#${goto 15}|${goto 38}+-- ${color3}Node:${alignr}${color6}${nodename}${font}${color}
#${goto 15}|${goto 38}+-- ${color3}Machine:${alignr}${color6}${machine}${color}
${goto 15}|${goto 38}+-- ${color3}Uptime:${alignr}${color6}${uptime_short}${color}
${goto 15}|${goto 38}+-- ${color3}Entropy${alignr}${color1}${entropy_perc}% ${color6}(${entropy_avail}/${entropy_poolsize})${color}
${goto 15}|
${goto 12}${color1}+----Status${color}
${goto 15}|${goto 38}${color1}+-- Cpu ${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Usage${alignr}${color1}${cpu cpu0}% ${color6}- ${freq_g}GHz${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}LoadAvg${alignr}${color6}${loadavg}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Temp${alignr}${color1}${execi 10 sensors | grep 'Core 0' | awk {'print $3'}}${color}
${goto 15}|${goto 38}+-- ${color1}Ram${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${memmax}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}In Use${alignr}${color6}${mem} ${color1}(${memperc}%)${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${memfree}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Up to${alignr}${color6}${memeasyfree}${color}
${goto 15}|${goto 38}+-- ${color1}Swap${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${swapmax}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Used${alignr}${color6}${swap} - ${swapperc}%${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${swapfree}${color}
${goto 15}|${goto 38}${color1}+-- Storage ${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Total${alignr}${color6}${fs_size /}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Used${alignr}${color6}${fs_used /} ${color1}(${fs_used_perc}%)
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Free${alignr}${color6}${fs_free /}${color}
${goto 15}|${goto 38}${color1}+-- Diskio ${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Read${alignr}${color6}${diskio_read}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}Write${alignr}${color6}${diskio_write}${color}
${goto 12}${color1}+----Processes ${color}
${goto 15}|${goto 38}+-- ${color3}Total${alignr}${color6}${processes}${color}
${goto 15}|${goto 38}+-- ${color3}Running${alignr}${color6}${running_processes}${color}
${goto 15}|${goto 38}+-- ${color1}Cpu${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 1}${alignr}${color6}${top cpu 1}${top mem 1}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 2}${alignr}${color6}${top cpu 2}${top mem 2}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top name 3}${alignr}${color6}${top cpu 3}${top mem 3}${color}
${goto 15}|
${goto 15}|${goto 38}+-- ${color1}Mem${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 1}${alignr}${color6}${top_mem cpu 1}${top_mem mem 1}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 2}${alignr}${color6}${top_mem cpu 2}${top_mem mem 2}${color}
${goto 15}|${goto 40}|${goto 60}+-- ${color3}${top_mem name 3}${alignr}${color6}${top_mem cpu 3}${top_mem mem 3}${color}
${goto 15}|
Yes, ususally I edit those standard. But now in this case I can not find config file..Maybe I will try to reinstall conky
Nope, dos not help.
Please edit headline, it is not the preinstalled conky.
Start reading manuals, please.
We cant teach this conky, its sometimes complex and different for each hardware outside in the world.
Ok, sorry.. I find a way.. Nothing useful on Conky wiki, but found it on Arch wiki xD
P.S.
Eagle is there.. now I can edit it..hehe..thanks @SGS and @tbg
I am a little inpatient, need to start read first and than ask for a help xD
