I wand to edit the installed conky but conky manager isn't giving me anything useful how do i edit the preinstalled conky BTW I use regular kde
~/.config/conky/
and
find
is a powerful command
Is there a gui for this or at least a tutorial
For find or conky?
To edit the conky that comes with KDE
I use Kate or Geany to edit conky.conf.
Web is full of conky tutorials.
Thanks Ill try soon
Hi, I dont have that folder.
Also when I run conky, I got default Garuda setup I think, but dont know how to edit it. Because I dont have .config/conky/ folder.
Also via Gui manager, I can not run any preset conky, It doesnt load
This generally happens after you've run out alcohol at your residence. The cure not surprisingly, is to hit the liquor store and replenish your alcohol supplies ASAP.
In this day and age with uncertain inventory supplies you need to be extremely vigilant about restocking before you run dry. Otherwise, all manners of horrors may befall you,.
One can never be too careful.
Its a dot folder = hidden
Use file browser and press Ctrl + h
ls -la .config/conky
I know that. I have it unhidden, but still not there xD
╰─λ ls -la .config/conky
".config/conky": No such file or directory (os error 2)
Use
find
then. If there is no conky file how it starts as you said?
Are you in ~
for ls -la ?
[htpc@htpc2 ~]$ ls -la $HOME/.config/conky
total 8
drwxr-xr-x 1 htpc htpc 20 Aug 30 22:37 .
drwxr-xr-x 1 htpc htpc 2636 Dec 12 05:15 ..
-rw-r--r-- 1 htpc htpc 5689 Aug 30 07:25 conky.conf
yes, I am
─marko at marko-hpenvyx360convertible13ar0xxx in ⌁/.config ╰─λ ls -la .config/conky ".config/conky": No such file or directory (os error 2) ╭─marko at marko-hpenvyx360convertible13ar0xxx in ⌁/.config ╰─λ find . ./alacritty ./alacritty/alacritty.yml ./autostart ./autostart/libinput-gestures.desktop ./autostart/org.ksnip.ksnip.desktop ./autostart/redshift-gtk.desktop ./autostart/setup-assistant.desktop ./autostart/variety.desktop ./autostart/xdman.desktop ./autostart/org.kde.latte-dock.desktop ./autostart/setup.desktop ./autostart/conky.desktop ./bleachbit ./bleachbit/bleachbit.ini ./deluge ./deluge/gtk3ui.conf ./falkon ./falkon/profiles ./falkon/profiles/garuda ./falkon/profiles/garuda/bookmarks.json ./falkon/profiles/garuda/browsedata.db ./falkon/profiles/garuda/version ./falkon/profiles/profiles.ini ./ksnip ./ksnip/ksnip.conf ./micro ./micro/plug ./micro/plug/aspell ./micro/plug/aspell/help ./micro/plug/aspell/help/aspell.md ./micro/plug/aspell/LICENSE ./micro/plug/aspell/README.md ./micro/plug/aspell/aspell.lua ./micro/plug/aspell/repo.json ./micro/plug/fzf ./micro/plug/fzf/README.md ./micro/plug/fzf/main.lua ./micro/plug/fzf/repo.json ./micro/plug/wc ./micro/plug/wc/help ./micro/plug/wc/help/wc.md ./micro/plug/wc/CHANGELOG.md ./micro/plug/wc/LICENSE ./micro/plug/wc/README.md ./micro/plug/wc/info.json ./micro/plug/wc/repo.json ./micro/plug/wc/wc.lua ./micro/settings.json ./mpv ./mpv/mpv.conf ./psd ./psd/psd.conf ./psd/.psd.conf ./pulseaudio-ctl ./pulseaudio-ctl/config ./smplayer ./smplayer/file_settings ./smplayer/file_settings/0 ./smplayer/file_settings/0/05419e514627847a.ini ./smplayer/file_settings/0/06186e9b5fc6139f.ini ./smplayer/file_settings/0/094faa6e2b69b7f8.ini ./smplayer/file_settings/0/0c80411c22f580b1.ini ./smplayer/file_settings/0/0c83477889b04efd.ini ./smplayer/file_settings/0/0e823ada293f81cf.ini ./smplayer/file_settings/1 ./smplayer/file_settings/1/1090ed6bd5732ddd.ini ./smplayer/file_settings/1/1141aeef283451b4.ini ./smplayer/file_settings/1/157b8ec8fcba8015.ini ./smplayer/file_settings/1/18861d0c2d18f2d4.ini ./smplayer/file_settings/2 ./smplayer/file_settings/2/2263e6af281224e6.ini ./smplayer/file_settings/2/22c5fc4768b9a648.ini ./smplayer/file_settings/2/25bd35564b0cf671.ini ./smplayer/file_settings/2/25d0e62075930b55.ini ./smplayer/file_settings/2/2ef78a3b573f578f.ini ./smplayer/file_settings/3 ./smplayer/file_settings/3/34944e9d15717fcc.ini ./smplayer/file_settings/3/36e6a9e8f425d42a.ini ./smplayer/file_settings/3/3f2ec6e8680a7493.ini ./smplayer/file_settings/3/3f9f03eadf38f42d.ini ./smplayer/file_settings/4 ./smplayer/file_settings/4/41103f56d94fd651.ini ./smplayer/file_settings/4/4119bc746fd273be.ini ./smplayer/file_settings/4/426972c6aa6021e2.ini ./smplayer/file_settings/4/44793c7b7a4f6600.ini ./smplayer/file_settings/4/44ba252a9b2a6f0b.ini ./smplayer/file_settings/4/48a3005df337f031.ini ./smplayer/file_settings/4/49d1961f8f939419.ini ./smplayer/file_settings/5 ./smplayer/file_settings/5/519ab480a45cd7ed.ini ./smplayer/file_settings/5/51c182b02833bb50.ini ./smplayer/file_settings/5/5438df3674b6d0d3.ini ./smplayer/file_settings/5/5881da9f57e2ae89.ini ./smplayer/file_settings/5/5989ff06d380dbb5.ini ./smplayer/file_settings/5/5a58345202360135.ini ./smplayer/file_settings/5/5cf390e4ee12ba6b.ini ./smplayer/file_settings/5/5f5d311204ae3e93.ini ./smplayer/file_settings/5/5f8f3b698e5b374d.ini ./smplayer/file_settings/6 ./smplayer/file_settings/6/683d686926ef62cc.ini ./smplayer/file_settings/6/6ad071f92d1b9472.ini ./smplayer/file_settings/6/6e775d6e3162d034.ini ./smplayer/file_settings/7 ./smplayer/file_settings/7/7767a33e4dcd8cf8.ini ./smplayer/file_settings/7/77ada7a4bca68d25.ini ./smplayer/file_settings/7/7f740a01da03c28d.ini ./smplayer/file_settings/8 ./smplayer/file_settings/8/8028530024b481ea.ini ./smplayer/file_settings/8/8b7b182d50684c27.ini ./smplayer/file_settings/8/8c8a5e8d4844c408.ini ./smplayer/file_settings/8/8da80829ac45fc94.ini ./smplayer/file_settings/9 ./smplayer/file_settings/9/90523e7ab4f9f761.ini ./smplayer/file_settings/9/98bc7a2d3d65fa2c.ini ./smplayer/file_settings/9/99250efd3b661126.ini ./smplayer/file_settings/9/9a14fc763145e428.ini ./smplayer/file_settings/9/9e5d74b83dbe2a93.ini ./smplayer/file_settings/9/9fe43666c153e1ac.ini ./smplayer/file_settings/M ./smplayer/file_settings/M/MC8wNzU2NDoxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/M/MS80NDEyNjoxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/M/MS84NzQ0NToxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/M/MS8wMjM0NToxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/M/My84NTQxNDoxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/N ./smplayer/file_settings/N/NHBtLnAwMjdfVU9zZlRCUnlBQkJfdXJwYXNfeWFuaXZfb2FyX2FraWhkYXJfcmFtdWtfbmFoc3VoYl9kX2xpaGtpbl9paGNnYWJfa2hzaW5hdF9pbGFoc3VuYWhiX2luYXZoZF9nbm9zX2V0c2FhdiAtIG1vYy5ldGFtMnkvc2Rhb2xud29kL2VnYXJvdFMgbGFucmV0bkkvQjAyMkYvOnB0bQ==.ini ./smplayer/file_settings/N/NzFiMzNiNzJhMDk0LTE0YzgtNTk1NC1hZjNjLWZkZWFkYzU1L2FpZGVtL3dlaXZlcnAvNDE2OToxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/Y ./smplayer/file_settings/Y/YmZkODFkZTgxYWY2LTc4NWEtNWYxNC1jNzNjLWE4NWQwMGZmL2FpZGVtL3dlaXZlcnAvNDE2OToxLjAuMC43MjEvLzpwdHRo.ini ./smplayer/file_settings/a ./smplayer/file_settings/a/a3eba8d676c981cf.ini ./smplayer/file_settings/a/a43e624fedaeaf77.ini ./smplayer/file_settings/a/a58c9bb2c8019396.ini ./smplayer/file_settings/a/ad51e79a833f5603.ini ./smplayer/file_settings/a/aefb6417d9b4a68e.ini ./smplayer/file_settings/b ./smplayer/file_settings/b/b0dab95dca6f6fd3.ini ./smplayer/file_settings/b/b3d4999f76638f19.ini ./smplayer/file_settings/b/bb6bc61b942eb879.ini ./smplayer/file_settings/b/bd8e5eda1d07e594.ini ./smplayer/file_settings/b/bf10a58c5e697be2.ini ./smplayer/file_settings/c ./smplayer/file_settings/c/c1563d2639f495d3.ini ./smplayer/file_settings/c/c1d1beed2e73e032.ini ./smplayer/file_settings/c/c57528b3a8d349b7.ini ./smplayer/file_settings/c/c5e0197be6c31726.ini ./smplayer/file_settings/c/cGczLjg1MDBfRElWL1NPSUFLMDAxL01JQ0QvZWdhcm90UyBsYW5yZXRuSS9CMDIyRi86cHRt.ini ./smplayer/file_settings/c/cad2268ba3a93259.ini ./smplayer/file_settings/d ./smplayer/file_settings/d/d2000df2593c99cb.ini ./smplayer/file_settings/d/d80aeff9d07c8779.ini ./smplayer/file_settings/d/db785da4ff34420a.ini ./smplayer/file_settings/d/dd11ef9688d0caf6.ini ./smplayer/file_settings/d/df3f1ed5b8f1f953.ini ./smplayer/file_settings/e ./smplayer/file_settings/e/e39c59f3c8491316.ini ./smplayer/file_settings/e/e6ab8ac6ae632260.ini ./smplayer/file_settings/e/e76cf192b36f9ac3.ini ./smplayer/file_settings/e/e946c6c174e58174.ini ./smplayer/file_settings/e/ebd5a7c57c8a02d1.ini ./smplayer/file_settings/e/ec5c752f680383f0.ini ./smplayer/file_settings/f ./smplayer/file_settings/f/f1c5449c0d4c2fb7.ini ./smplayer/file_settings/f/f408ad7a706d58bb.ini ./smplayer/file_settings/f/f417e825aa08ab91.ini ./smplayer/file_settings/f/f8c4163ca7a6ecd1.ini ./smplayer/file_settings/f/fb287e46c818a25e.ini ./smplayer/file_settings/f/fc99aa562d2c499e.ini ./smplayer/file_settings/f/fd509601a6d7c9ec.ini ./smplayer/file_settings/f/fe78aafc96e8b476.ini ./smplayer/file_settings/f/ff631fbcf4b4f4a6.ini ./smplayer/device_info.ini ./smplayer/favorites.m3u8 ./smplayer/hdpi.ini ./smplayer/player_info.ini ./smplayer/playlist.ini ./smplayer/radio.m3u8 ./smplayer/smplayer.ini ./smplayer/styles.ass ./smplayer/tv.m3u8 ./variety ./variety/variety.conf ./vlc ./vlc/vlc-qt-interface.conf ./vlc/vlcrc ./linux-steam-integration.conf ./Kvantum ./Kvantum/kvantum.kvconfig ./alacritty_themed ./alacritty_themed/alacritty.yml ./autostart-scripts ./autostart-scripts/setup.sh ./fish ./fish/config.fish ./fish/fish_variables ./gtk-3.0 ./gtk-3.0/colors.css ./gtk-3.0/gtk.css ./gtk-3.0/settings.ini ./latte ./latte/.multiple-layouts_hidden.layout.latte ./latte/Garuda.layout.latte ./neofetch ./neofetch/config.conf ./libinput-gestures.conf ./touchpadrc ./touchpadxlibinputrc ./user-dirs.dirs ./user-dirs.locale ./plasma-localerc ./xsettingsd ./xsettingsd/xsettingsd.conf ./dconf ./dconf/user ./libaccounts-glib ./libaccounts-glib/accounts.db ./libaccounts-glib/accounts.db-wal ./libaccounts-glib/accounts.db-shm ./ktimezonedrc ./baloofilerc ./pulse ./pulse/cookie ./pulse/399f03eadd0a4d8fa07f1b1754e38184-device-volumes.tdb ./pulse/399f03eadd0a4d8fa07f1b1754e38184-stream-volumes.tdb ./pulse/399f03eadd0a4d8fa07f1b1754e38184-card-database.tdb ./pulse/399f03eadd0a4d8fa07f1b1754e38184-default-sink ./pulse/399f03eadd0a4d8fa07f1b1754e38184-default-source ./kmixrc ./akregatorrc ./kateschemarc ./gwenviewrc ./kde.org ./kde.org/UserFeedback.org.kde.plasmashell.conf ./kde.org/UserFeedback.org.kde.kate.conf ./kde.org/UserFeedback.org.kde.dolphin.conf ./kdeconnect ./kdeconnect/privateKey.pem ./kdeconnect/certificate.pem ./kdeconnect/config ./ksmserverrc ./kwinrulesrc ./okularpartrc ./spectaclerc ./kded5rc ./kactivitymanagerdrc ./plasma-nm ./kwalletrc ./systemd ./systemd/user ./systemd/user/default.target.wants ./systemd/user/default.target.wants/psd.service ./session ./session/dolphin_dolphin_dolphin ./kconf_updaterc ./garuda ./garuda/garuda-settings-manager.conf ./garuda/garuda-settings-manager-Notifier.conf ./cef_user_data ./cef_user_data/Dictionaries ./pamac ./pamac/size ./knfsshare ./baloofileinformationrc ./sddmthemeinstallerrc ./kdeglobals ./plasmarc ./kcminputrc ./ksplashrc ./kscreenlockerrc ./protonfixes ./protonfixes/mscorefonts ./trashrc ./ksysguardrc ./powermanagementprofilesrc ./arkrc ./bluedevilglobalrc ./plasmashellrc ./plasmanotifyrc ./gtkrc ./gtkrc-2.0 ./Trolltech.conf ./kxkbrc ./khotkeysrc ./kwinrc ./plasma-org.kde.plasma.desktop-appletsrc ./kglobalshortcutsrc ./kinfocenterrc ./katerc ./katemetainfos ./katevirc ./conky-manager.json ./lattedockrc ./systemsettingsrc ./kactivitymanagerd-statsrc ./dolphinrc ./konsolerc
no, you are in .config
Next, has the conky white head eagle on top?
If not it is the standard conky file.
no, it seems it is standard one..what now ?
Read conky manuals or use Garuda conky.conf
/etc/skel/.config/conky/conky.conf
I know some basics. For example I edited my conky on LXQT Garuda. Because conky folder is there..
