How do I delete nextcloud?
Sorry if this is a dumb question but I cannot for the life of me figure out how to get rid of it. The program opens up almost every time I download something and I will never use it.
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7b56fc96-0e19-473d-badd-73a065550c34 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.80
date: 12/15/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3674 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3693
3: 3700 4: 3700 5: 3700 6: 3600 7: 3600 8: 3700 9: 3700 10: 3600 11: 3700
12: 3700 bogomips: 88805
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2d:00.0
chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
navi22 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2725
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0032
Local Storage: total: 14.81 TiB used: 3.71 TiB (25.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000NM001G-2KJ103
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 443.54 GiB (23.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 443.54 GiB (23.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: zram size: 15.54 GiB used: 102.5 MiB (0.6%)
System Temperatures: cpu: 62.4 C mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 58.0 C
Processes: 366 Uptime: 3h 47m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 7.95 GiB (51.2%) Init: systemd v: 255
pm: pacman pkgs: 1824 libs: 533 tools: octopi,paru,yay Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2023-12-16
Last full system update: 2024-01-17
Try the usual
sudo pacman -R nextcloud
But I don’t know if there are dependencies.
That was my first attempt but it tells me target not found.
╭─zoey@CUMMY in ~
╰─λ sudo pacman -R nextcloud
[sudo] password for zoey:
error: target not found: nextcloud
╭─zoey@CUMMY in ~ as 🧙 took 2s
sudo pacman -R nextcloud-client
Oh my god thank you so much!!! I feel so dumb but at the same time I couldn’t find good information anywhere.
