Hi
I am using corectrl and faced an issue which should be solved by applying a patch to my kernel. Please read here.
i went through some forums and arch wiki page but my dumb ass didn't understand anything, so a detailed guide would be helpful that how can i patch my kernel with that file?
i tried patch -i /home/muza/Downloads/0001-drm-amdgpu-pm-fix-powerplay-OD-interface.patch
output:
can't find file to patch at input line 25
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|From 42791d8ca2eb407d178d3f269485b6eb6f119fba Mon Sep 17 00:00:00 2001
|Date: Tue, 23 Nov 2021 11:36:01 -0500
|Subject: [PATCH] drm/amdgpu/pm: fix powerplay OD interface
|The overclocking interface currently appends data to a
|string. Revert back to using sprintf().
|Bug: https://gitlab.freedesktop.org/drm/amd/-/issues/1774
|Fixes: 6db0c87a0a8ee1 ("amdgpu/pm: Replace hwmgr smu usage of sprintf with sysfs_emit")
|Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
| .../drm/amd/pm/powerplay/hwmgr/smu10_hwmgr.c | 20 +++----
| .../drm/amd/pm/powerplay/hwmgr/smu7_hwmgr.c | 24 ++++----
| .../drm/amd/pm/powerplay/hwmgr/smu8_hwmgr.c | 6 +-
| .../drm/amd/pm/powerplay/hwmgr/vega10_hwmgr.c | 28 +++++----
| .../drm/amd/pm/powerplay/hwmgr/vega12_hwmgr.c | 10 ++--
| .../drm/amd/pm/powerplay/hwmgr/vega20_hwmgr.c | 58 +++++++++----------
| 6 files changed, 67 insertions(+), 79 deletions(-)
|diff --git a/drivers/gpu/drm/amd/pm/powerplay/hwmgr/smu10_hwmgr.c b/drivers/gpu/drm/amd/pm/powerplay/hwmgr/smu10_hwmgr.c
|index 258c573acc97..1f406f21b452 100644
|--- a/drivers/gpu/drm/amd/pm/powerplay/hwmgr/smu10_hwmgr.c
|+++ b/drivers/gpu/drm/amd/pm/powerplay/hwmgr/smu10_hwmgr.c
File to patch:
