Hi everyone, brand new linux user here attempting to switch from a Windows power-user to Garuda daily driver. I’m finding most things to be fairly intuitive, but have run into an issue. I’ve got some pretty severe photosensitivity issues, and I know Bottles has a dark mode that it claims it turns on through the system’s theme preferences rather than giving the users a toggle.
I’ve seen terminal based solutions for turning this on in its flatpak iteration:
flatpak run --command=bash com.usebottles.bottles gsettings set com.usebottles.bottles dark-theme true
But since Garuda doesn’t support flatpak, I’m not sure how to achieve the same effect here, and I can’t seem to find any information online that doesn’t assume Bottles is installed as a flatpak. I’ve also read something about a configuration file somewhere, but have no idea where to find such a thing on this new system.
Can anyone give me some guidance on this?
And more broadly, are there any beginner-friendly resources out there that explain things like where configurations for Garuda Linux typically live in file storage? Is there any sort of way to translate a command like this into an equivalent this system will use? Or what types of syntax/terminal commands Garuda will need you to be familiar with for the basics?
Forgive any presumptions here, I’ve done my best to research before asking. Definitely feeling a little lost in this new world but excited to learn!
Thanks!
I think I babbled my way into not being clear, sorry.
Bottles was installed when I set up Garuda, so it is here. (And I’ve used pacman to install a few other things already! So that works great!)
I just don’t know how to turn on the Dark Mode in Bottles here, it’s stuck in Light Mode. I only mentioned flatpak above because people had mentioned a way to enable it via command when it was installed with flatpak.
Is there a command I can use with pacman to force Dark Mode on Bottles?
Nevermind!! I think i figured it out. I’m not entirely sure what worked, but I experimented with variations of this part of the command by itself or with “pacman” in front.
I’m not sure which worked, but after a restart, I’ve got dark mode Bottles!
Thanks again for the welcome. I look forward to continuing to learn this new system!
