Hello,
apparently when I'm trying to access one of my internal hard drives especially in GTK/Gnome apps I'm receiving I/O error and I can't get inside. However there's no problem in other apps or my OS and I/O read and write is working like it should. I'm thinking that it's something remaining from before when I was with Windows.
Anyways, when I go through the drives I saw that one of the drives - the working one is having 3 hidden folders - .Trash-1000
, $RECYCLE.BIN
and System Volume Information
, but the problematic drive only has .Trash-1000
so it seems that I get this error, because my System Volume Information
folder is missing.
Anyone having an idea how can I fix this? Is there a way of creating that folder? or Can I use a Windows VM to try to fix this? How should I proceed?
Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=90aeb098-5302-49d3-a3fe-482d1815c7f2 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.B1
date: 06/10/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3001 high: 3600 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2810 2: 2650
3: 2871 4: 2880 5: 3599 6: 3001 7: 3600 8: 2879 9: 3028 10: 2223 11: 3597
12: 2879 bogomips: 88802
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: PNY driver: nvidia
v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2487
Screen-1: 0 s-res: 6960x1920 s-dpi: 91 s-size: 1944x536mm (76.54x21.10")
s-diag: 2017mm (79.39")
Monitor-1: DP-0 pos: primary,top-center res: 3840x1600 hz: 60 dpi: 111
size: 879x366mm (34.61x14.41") diag: 952mm (37.49") modes: N/A
Monitor-2: DP-2 pos: top-left res: 1200x1920 hz: 60 dpi: 94
size: 324x518mm (12.76x20.39") diag: 611mm (24.05") modes: N/A
Monitor-3: DP-4 pos: bottom-r res: 1920x1080 hz: 60 dpi: 92
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Intel USB PnP Sound Device
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 8086:0808 class-ID: 0300
API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
IF-ID-1: br-0158dadbc9c5 state: down mac: <filter>
IF-ID-2: br-96ccd0623b5d state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-4: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-5: veth1dd6268 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vetha2daaf6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethcbcfb37 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-9: vnet1 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 2357:0604
Local Storage: total: 4.1 TiB used: 2.39 TiB (58.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1014 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20110000 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: GPT
used: 100.13 GiB (21.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 143.5 MiB (0.4%)
System Temperatures: cpu: 35.0 C mobo: 33.0 C gpu: nvidia temp: 57 C
Fan Speeds (RPM): fan-1: 1829 fan-2: 852 fan-3: 730 fan-4: 0 fan-5: 0
fan-6: 0 gpu: nvidia fan: 0%
Processes: 396 Uptime: 11h 21m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 18.09 GiB (57.9%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1870 libs: 469 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-22
Last full system update: 2023-07-23 ↻
