Hello Garuda users.
I am wondering if anyone knows how to enable variable refresh rate on AMDGPU in KDE Plasma X11 please?
I have followed the ArchWiki but still no luck after I add
Option "VariableRefresh" "true"
To the /usr/share/X11/xorg.cong.d/10-amdgpu.conf
file
type or paste code here
I also have the kernel parameter amdgpu.freesync_video=1
set so freesync is enabled as I get
[🔴] × systool -vm amdgpu | grep free
freesync_video = "1"
But I keep getting the following on reboot
vrr_capable: 0
I can set it to 1 manually
DISPLAY=:0 xrandr --output HDMI-A-1 --set "vrr_capable" 1
Not sure what I am missing
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=268fc465-6b64-4b70-80a7-498d22cc24d5 rw rootflags=subvol=@
quiet quiet amdgpu.freesync_video=1 rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=2e2d0ab6-f6a2-4710-98e2-bdb05e0b6b7f loglevel=3
Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF
Mobo: Gigabyte model: X570 AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F37b date: 02/08/2023
Device-1: hidpp_battery_0 model: Logitech Craft Advanced Keyboard
status: full
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3736 high: 4300 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3772 2: 3500
3: 3791 4: 3600 5: 3500 6: 4300 7: 3500 8: 3743 9: 3500 10: 3815 11: 3500
12: 3820 13: 4235 14: 4234 15: 3710 16: 3740 17: 3764 18: 4254 19: 3500
20: 3689 21: 4246 22: 3500 23: 4172 24: 3500 25: 3812 26: 3500 27: 3856
28: 3500 29: 3500 30: 3500 31: 3500 32: 3500 bogomips: 224014
Device-1: Blackmagic Design DeckLink Quad HDMI Recorder driver: N/A pcie:
gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 05:00.0
chip-ID: bdbd:a14e class-ID: 0400
Device-2: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire NITRO+
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0e:00.0 chip-ID: 1002:744c
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: Onkyo AV Receiver built: 2021
res: 3840x2160 dpi: 52 gamma: 1.2 size: 1872x1053mm (73.7x41.46")
diag: 1630mm (64.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 7900 XTX (gfx1100
LLVM 15.0.7 DRM 3.52 6.4.8-zen1-1-zen) direct-render: Yes
Device-2: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: b58e:9e84 class-ID: 0300
Device-5: Nam Tai E&E Products or OmniVision Sony Playstation Eye
driver: ov534,snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-4:4 chip-ID: 1415:2000 class-ID: 0102
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:9 chip-ID: 8087:0029
Local Storage: total: 6.37 TiB used: 4.12 TiB (64.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 48.9 C scheme: GPT
model: WDS100T1XHE-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 614600WD temp: 50.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 010
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 2TB
tech: SSD serial: <filter> fw-rev: 1B6Q
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 496.2 GiB (27.7%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 496.2 GiB (27.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 2.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.99 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 67.1 C mobo: 43.0 C gpu: amdgpu temp: 53.0 C
mem: 68.0 C
Fan Speeds (RPM): fan-1: 1083 fan-2: 0 fan-3: 0 gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.27 gpu: amdgpu watts: 28.00
Processes: 591 Uptime: 10h 1m wakeups: 307 Memory: total: 64 GiB note: est.
available: 62.71 GiB used: 8.15 GiB (13.0%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2076 libs: 567 tools: octopi,pamac,paru
inxi: 3.3.28
System install date: 2023-05-13
Last full system update: 2023-08-10
