How can I clone my hard drive?
Kernel: 5.16.3-241-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux516-tkg-pds
root=UUID=2230677d-5ca8-44dd-a833-30d1b43c58a6 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450M-A PRO MAX (MS-7C52) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 3.C0
date: 05/19/2021
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3992 high: 4203 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3611 2: 4199
3: 4191 4: 3599 5: 4055 6: 3573 7: 4200 8: 4203 9: 3821 10: 4064 11: 4198
12: 4201 bogomips: 86402
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 29:00.0
chip-ID: 10de:21c4 class-ID: 0300
Device-2: KYE Systems (Mouse Systems) Genius Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 0458:6006
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4")
s-diag: 692mm (27.2")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.1 chip-ID: 10de:1aeb
driver: snd_hda_intel v: kernel bus-ID: 2b:00.4 chip-ID: 1022:1487
Device-3: KYE Systems (Mouse Systems) Genius Webcam type: USB
Sound Server-1: ALSA v: k5.16.3-241-tkg-pds running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 143.19 GiB (7.7%)
rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
used: 143.19 GiB (15.4%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: zram size: 15.61 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1603 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 42%
Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.34
Processes: 349 Uptime: 1m wakeups: 0 Memory: 15.61 GiB
used: 6.05 GiB (38.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1945 pacman: 1938 lib: 559 snap: 7 Shell: fish
Garuda (2.5.4-2):
System install date:     2022-01-27
Last full system update: 2022-02-16
Failed units:            bluetooth-autoconnect.service
type or paste code here
Hi, I recently bought a m.2 and I want to clone my hard drive to it. I tried clonezilla and it didn't work, the system wasn't booting. I tried in gparted to copy the patitions and paste them in the m.2, that didn't work either. Do I need to reinstall or is it any way to clone it? Almost forgot, I also tried the dd command and yeah......it didn't work.
As this is only a twenty day old install if none of the above is working why not just install on the new drive and then copy your home directory from one to the other
Clonezilla should do it but you will likely have to chroot into the install and reinstall grub, might have to check the UUID in fstab as well.
@TilliDie raises a good point as well.
Well, this really didn't cross my mind...Thanks!
