How can i change switch workspace with single key without pressing modkey etc
i’am using garuda hyperland How can i change switch workspace with single key without pressing modkey and like i want to switch workspace pressing f1 single button please help anyone
check hyprland.conf
you find these things
bind = $mainMod, F1, exec, firedragon
bind = $mainMod, F2, exec, thunderbird
bind = $mainMod, F3, exec, thunar
bind = $mainMod, F4, exec, geany
bind = $mainMod, F5, exec, github-desktop
bind = $mainMod, F6, exec, gparted
bind = $mainMod, F7, exec, inkscape
bind = $mainMod, F8, exec, blender
bind = $mainMod, F9, exec, meld
bind = $mainMod, F10, exec, joplin-desktop
bind = $mainMod, F11, exec, snapper-tools
bind = $mainMod, F12, exec, galculator
and
bind = $mainMod, 1, workspace, 1
bind = $mainMod, 2, workspace, 2
bind = $mainMod, 3, workspace, 3
bind = $mainMod, 4, workspace, 4
bind = $mainMod, 5, workspace, 5
bind = $mainMod, 6, workspace, 6
bind = $mainMod, 7, workspace, 7
bind = $mainMod, 8, workspace, 8
bind = $mainMod, 9, workspace, 9
bind = $mainMod, 0, workspace, 10
combine them like this :
bind = ,F1,workspace,1
bind = ,F2,workspace,2
bind = ,F3,workspace,3
bind = ,F4,workspace,4
bind = ,F5,workspace,5
bind = ,F6,workspace,6
bind = ,F7,workspace,7
bind = ,F8,workspace,8
bind = ,F9,workspace,9
bind = ,F10,workspace,10
then remove the other conflicting key bindings , and you are good to go !!!
You can assign multiple key bindings for the same thing
:warning: WARNING!!! :warning:
Do it at your own risk we are not liable for any problem that may happen
tried not working no errors shown
Check wiki
Notebook?
3-Finger swipe, left-right.
i have pc will f1 keywork ?
now working with f1 thanks for help
well, that’s strange
It is working in my laptop :eyes:
maybe an update would do it ?
i have installed garuda hyprland on external ssd so i tried in pc and macbook air in pc it works fine i need this for pc in macbook air swipe gesture works fine
install wev
sudo pacman -S wev
now, open wev with the command wev
now press f1 key and note what key number you get ,
you can see my out put :
 ╭─ankur@ankur in ~
 ╰─λ wev
[04:         wl_seat] name: Hyprland
[04:         wl_seat] capabilities: pointer keyboard
[10:    xdg_toplevel] configure: width: 935; height: 1046
                      tiled-left tiled-right tiled-top tiled-bottom
[09:     xdg_surface] configure: serial: 1507
[14:     wl_keyboard] keymap: format: 1 (xkb v1), size: 64754
[14:     wl_keyboard] repeat_info: rate: 25 keys/sec; delay: 600 ms
                      tiled-left tiled-right tiled-top tiled-bottom maximized
[10:    xdg_toplevel] configure: width: 921; height: 1026
[14:     wl_keyboard] enter: serial: 1511; surface: 3
[14:     wl_keyboard] modifiers: serial: 0; group: 16
                      depressed: 00000000
                      latched: 00000000
                      locked: 00000010: Mod2
[11:  wl_data_device] selection: (cleared)
                      tiled-left tiled-right tiled-top tiled-bottom maximized activated
[10:    xdg_toplevel] configure: width: 917; height: 1022
[13:      wl_pointer] enter: serial: 1514; surface: 3, x, y: 809.570312, 625.511719
[13:      wl_pointer] frame
[09:     xdg_surface] configure: serial: 1508
[14:     wl_keyboard] key: serial: 1515; time: 272256; key: 36; state: 0 (released)
                      sym: Return       (65293), utf8: ''
[14:     wl_keyboard] key: serial: 1517; time: 275088; key: 67; state: 1 (pressed)
                      sym: F1           (65470), utf8: ''
[14:     wl_keyboard] key: serial: 1518; time: 275177; key: 67; state: 0 (released)
[14:     wl_keyboard] key: serial: 1519; time: 276205; key: 133; state: 1 (pressed)
                      sym: Super_L      (65515), utf8: ''
                      depressed: 00000040: Mod4
                      latched: 00000000
[10:    xdg_toplevel] close
 ╭─ankur@ankur in ~ took 4s
 ╰─λ
here for f1 it said key : 67
so what I would do is I would replace f1 with 67 like this
bind = ,67,workspace,1
see if that works or not
That is what I can suggest, I don’t know any other way to configure it , if it doesn’t work , then it might be a big in Hyprland itself :eyes:
