how to setup network monitor like that on kde dr460nized? it looks neat
I'm using this widget...
thank you for your reply, it works..
I did the same but after downloading the applet when i added the widget, it is not showing the net speed. Its always 0.0 B/s
I am using KDE Dragonised (KDE plasma 5.22.3)
This topic is solved.
Check the settings, WLAN or Ethernet, use the one you needed.
Just tested this applet, works for me. However, you must actually be downloading something for it to display a speed.
Please do not necrobump old topics on the Garuda forum.
