Hi, I was wondering if there is an option to hotkey the suspend feature for the xfce desktop version. I set it in the battery settings to suspend when I close the lid on my laptop but it is not doing that, and clicking 2 buttons to suspend is kinda annoying. I was wondering if I could hotkey suspend so that way its 1 fluid motion.
inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f81321f4-94d4-4ee9-b8dc-5fe9bec7a14d rw [email protected]
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx
Mobo: HP model: 85FA v: 42.47 serial: <superuser required> UEFI: Insyde
v: F.50 date: 08/18/2021
ID-1: BAT1 charge: 30.8 Wh (82.6%) condition: 37.3/52.5 Wh (71.0%)
volts: 11.7 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1657 high: 3143 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 2670 2: 800 3: 800
4: 800 5: 800 6: 1287 7: 2960 8: 3143 bogomips: 38400
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c91
Device-3: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 03:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
address: <filter>
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 238.47 GiB used: 18.58 GiB (7.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: ADHA0102
temp: 32.9 C scheme: GPT
used: 18.58 GiB (7.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.61 GiB used: 209.2 MiB (2.7%)
System Temperatures: cpu: 29.8 C pch: 43.0 C mobo: 27.8 C gpu: nvidia
temp: 37 C
Processes: 305 Uptime: 1d 41m wakeups: 4 Memory: 7.61 GiB
used: 3.4 GiB (44.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1384 lib: 372 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.11
