Hello. As mention in the title I have a 240hz alienware monitor and it doesn't work properly on linux (but does in win10). I am not in a virtual machine but a dual boot.
So, when I'm at 60Hz no problem. But when I get a higher refresh rate it blinks rapidely or looks terrible like the colors are melting. It's a bit like if it is out of sinc.
I don't know how to find the driver. I have already made the "Auto install proprietary drivers" in the Garuda assistant but didn't work.
here is my inxi -Faz :
Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=370ea3c7-9b82-4197-9753-1a19e0880ea6
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 (MS-7B84) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.10 date: 10/09/2018
CPU: Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102385
Speed: 2796 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 2796 2: 2714
3: 2818 4: 2709 5: 3337 6: 2497 7: 2266 8: 2679 9: 2746 10: 2250 11: 2475 12: 2384 13: 2629
14: 3033 15: 3262 16: 3226
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI driver: nouveau v: kernel
bus-ID: 1f:00.0 chip-ID: 10de:1b82 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: DP-3 res: 1920x1080 hz: 60 dpi: 90 size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
OpenGL: renderer: NV134 v: 4.3 Mesa 21.2.4 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 1f:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: N/A modules: r8169 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp3s0f0u7 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host v: kernel bus-ID: 1-7:4
chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Device-2: Realtek 802.11ac NIC type: USB driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 0bda:b82c
Report: ID: hci0 rfk-id: 0 state: up address: <filter>
Drives: Local Storage: total: 1.93 TiB used: 24.23 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS120G2G0A-00JH30 size: 111.8 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB
serial: <filter> rev: 1A02 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000LX015-1U7172 size: 931.51 GiB
serial: <filter> rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 40.29 GiB size: 40.29 GiB (100.00%) used: 23.54 GiB (58.4%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw-size: 930.54 GiB size: 930.54 GiB (100.00%) used: 704 MiB (0.1%) fs: btrfs
dev: /dev/sdc1 maj-min: 8:33
ID-4: /var/log raw-size: 40.29 GiB size: 40.29 GiB (100.00%) used: 23.54 GiB (58.4%) fs: btrfs
ID-5: /var/tmp raw-size: 40.29 GiB size: 40.29 GiB (100.00%) used: 23.54 GiB (58.4%) fs: btrfs
ID-1: swap-1 type: zram size: 15.58 GiB used: 11.5 MiB (0.1%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 41.5 C mobo: N/A gpu: nouveau temp: 60.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info: Processes: 401 Uptime: 1h 20m wakeups: 0 Memory: 15.58 GiB used: 3.74 GiB (24.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1780 lib: 543
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
here is my lspci :
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0
to Bus B
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0
to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 59)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; F
unction 7
03:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller (rev 01)
03:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01)
03:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01)
16:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
16:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
16:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
16:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
16:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
16:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
1b:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Co
ntroller (rev 15)
1f:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070 Ti] (rev a1)
1f:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
20:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Du
mmy Function
20:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Securit
y Processor
20:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Zeppelin USB 3.0 Host controller
21:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Fu
nction
21:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
21:00.3 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller
Thank you for helping me
