3 days ago I ran garuda-update to install yuzu and ryujinx. While I successfully set up both when I played native PC games I had high gpu clock speed but low power draw, resulting in massive stutters and unplayable framerate (see pics below).
Normally in each game the cpu usage goes about 30-50%, and I can get more than 90 fps (KCD), 120 fps (modded Skyrim SE, no ENB), and 144 fps (AC7).
Commands I’d run prior to this problem:
garuda-update
pacman -S yuzu-mainline-bin ryujinx-git (chaotic aur)
pacman -Rns xone-dkms
pacman -S xpadneo-dkms
pacman -S nsz
I tried rebooting multiple times and running garuda-update again, no luck.
garuda-inxi:
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e481d90b-1737-47e5-89c1-bfb56c307a25 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X470-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5601
date: 07/10/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2516 high: 4101 min/max: 2200/4793 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 4100 5: 2200 6: 2200 7: 4101 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 98391
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0b:00.0 chip-ID: 1002:73ff
Monitor-1: DP-2 mapped: DisplayPort-1 model: Lenovo G24-20
serial: <filter> built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6600 XT (navi23
LLVM 15.0.7 DRM 3.52 6.4.3-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media dbE GAMING GM500
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
Device-2: Ralink RT2070 Wireless Adapter driver: rt2800usb type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:3 chip-ID: 148f:2070
IF: wlp13s0f3u4 state: up mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
Local Storage: total: 3.87 TiB used: 3.24 TiB (83.6%)
fw-rev: 4B2QEXM7 temp: 38.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-3: /dev/sdb maj-min: 8:16 vendor: V-Gen model: 09SM21AR256SDK 256GB
tech: SSD serial: <filter> fw-rev: 3A0 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1CH162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC49 scheme: GPT
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 53.73 GiB (44.8%)
used: 596 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 811.01 GiB size: 811.01 GiB (100.00%)
used: 582.78 GiB (71.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
used: 53.73 GiB (44.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 120 GiB size: 120 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.53 GiB used: 1.89 GiB (12.2%)
System Temperatures: cpu: 48.0 C mobo: 40.0 C gpu: amdgpu temp: 46.0 C
mem: 38.0 C
Fan Speeds (RPM): cpu: 1394 case-1: 1048 case-2: 1054 case-3: 1104
gpu: amdgpu fan: 0
Power: 12v: 12.03 5v: N/A 3.3v: N/A vbat: N/A gpu: amdgpu watts: 7.00
Processes: 442 Uptime: 15m wakeups: 0 Memory: total: 16 GiB
available: 15.53 GiB used: 5.37 GiB (34.6%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1704 libs: 490 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2022-08-04
Last full system update: 2023-07-13
Thanks beforehand!
