Hello.
So i have very weird issue with games specifically steam games. Some of them run very slowly and by that i mean like 20-30 fps with frametimes going between 20-600. I tried almost every proton version from 4.2-9 to proton experimental and proton ge 7.0 but no matter what i do the problem persists. I encountered this issue before and what resolved it was completely reinstalling the whole system which i'd prefer to avoid. I also tried using linux-lts but it didn't seem to help. Also i tried different launch options in Sword Art Online fatal bullet as my test game and what semi helped was using those but some games like f1 2019 completely break when using them. Also the games i tried to play were: Need for speed Heat, SAO Fatal Bullet, Grid 2 and Warframe. The last one is the most playable because those issues randomly appear and then disappear. CSGO and 2d games seem to run fine those same as older games like postal 2. Also im a newbie when it comes to linux
gamemoderun mesa_glthread=true PROTON_USE_WINED3D11=1 RADV_PERFTEST=aco VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/amd_icd32.json:/usr/share/vulkan/icd.d/amd_icd64.json %command%
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b6dde099-8cf7-4e35-8362-435fd7be6c77 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F51 date: 07/29/2020
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4005 high: 4042 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4030 2: 4041
3: 4013 4: 4041 5: 4042 6: 4041 7: 4040 8: 4010 9: 3938 10: 4040 11: 4020
12: 3805 bogomips: 86224
STIBP: disabled, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 06:00.0
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: HDMI-A-0 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.44.0
5.16.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 06:00.1
chip-ID: 1002:aaf0 class-ID: 0403
v: kernel bus-ID: 08:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA RC30-026902 Gaming Headset [Nari Essential Wireless
Receiver]
type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2
chip-ID: 1532:051e class-ID: 0300
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.44 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
Local Storage: total: 1.58 TiB used: 1.15 TiB (72.6%)
ID-1: /dev/sda maj-min: 8:0 model: SATA3 240GB SSD size: 223.57 GiB
serial: <filter> rev: 8B0 scheme: GPT
model: WD5000AAKS-07A7B2 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3B01
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
used: 201.76 GiB (90.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.64 GiB used: 2.34 GiB (14.9%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 205
Processes: 471 Uptime: 6h 53m wakeups: 7 Memory: 15.64 GiB
used: 8.1 GiB (51.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2068 lib: 574 flatpak: 0
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2021-11-25
Last full system update: 2022-01-31
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
