Hello all,
I’ve been having some temperature issues.
While running Steam (Native) temp increases to 60/70 C. It’s consuming around 70% of CPU only for having it open.
And while gaming, Path of Exile for example, CPU temp reaches over 90C.
Tried with different kernels (LTS and ZEN) but the issue persists.
Any additional info I could provide to track the root cause?
Note I don’t get these temps running other OS.
garuda-inxi:
Kernel: 6.6.5-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=51d05e24-fc7d-47db-9d28-178f113067e2 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G513IM_G513IM v: 1.0
Mobo: ASUSTeK model: G513IM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513IM.329 date: 03/01/2023
ID-1: BAT0 charge: 70.5 Wh (91.0%) condition: 77.5/90.0 Wh (86.1%)
volts: 16.5 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 3816 high: 4291 min/max: 400/4300 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4030 2: 3614 3: 3111
4: 3485 5: 4270 6: 4274 7: 3218 8: 3394 9: 4291 10: 3831 11: 4102 12: 4283
13: 2962 14: 3649 15: 4276 16: 4278 bogomips: 92660
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 60.0 C
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: right
model: ViewSonic VA1655-FHD serial: <filter> built: 2022 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: TL156VDXP01
built: 2020 res: 1920x1080 hz: 300 dpi: 142 gamma: 1.2
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.5-AMD-znver2) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1636 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir, snd_sof_amd_vangogh pcie:
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.5-AMD-znver2 status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 254.4 GiB (53.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 30.9 C scheme: GPT
used: 254.4 GiB (53.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.06 GiB used: 120.5 MiB (0.8%)
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 63.0 C
Fan Speeds (rpm): cpu: 3600
Processes: 403 Uptime: 44m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.06 GiB used: 6.15 GiB (40.8%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1852 libs: 557 tools: octopi,pamac,paru
Shell: fish v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-12-05
Last full system update: 2023-12-10
