Hello, i have a problem with Garuda. When the cpu usage go up the frequencies go down up to 1.6GHZ ando the usage go to 100% (The cpu is not heating 50º round) i dont know how to solve it.
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=611cef71-a577-4758-827a-f94542ee48c1 rw rootflags=subvol=@
intel_pstate=disable acpi=force cpufreq.default_governor=performance
quiet resume=UUID=ecea4256-472a-4a79-aadf-adf2b9972158 loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 81FK v: Lenovo ideapad 330-15ICH
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15ICH
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_81FK_BU_idea_FM_ideapad 330-15ICH
uuid: <superuser required> UEFI: LENOVO v: 7ZCN37WW date: 11/27/2020
ID-1: BAT0 charge: 26.5 Wh (81.0%) condition: 32.7/45.0 Wh (72.6%)
power: 15.7 W volts: 12.9 min: 11.3 model: SMP L17M3PB1 type: Li-poly
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2200 high: 2201 min/max: 800/2201 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2200 2: 2201
3: 2201 4: 2201 5: 2201 6: 2201 7: 2200 8: 2201 9: 2201 10: 2201 11: 2200
12: 2201 bogomips: 52799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2,HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0302
Device-3: Realtek EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 0bda:58ea
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
Screen-1: 0 s-res: 2065x2160 s-dpi: 96 s-size: 544x570mm (21.42x22.44")
s-diag: 788mm (31.02")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-left model: C200P
serial: <filter> built: 2023 res: 1920x1080 dpi: 93 gamma: 1.2
Monitor-2: eDP-1 pos: primary,bottom-r model: ChiMei InnoLux 0x15d5
built: 2015 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
GT2) device-ID: 8086:3e9b memory: 15.13 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 545.29.06
device-ID: 10de:1c8d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
Local Storage: total: 1.14 TiB used: 39.2 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS256GD9TNG-62A0A size: 238.47 GiB block-size: physical: 512 B
fw-rev: 80001E00 temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: <filter> fw-rev: LCM2 scheme: GPT
ID-1: / raw-size: 221.13 GiB size: 221.13 GiB (100.00%)
used: 39.2 GiB (17.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.13 GiB size: 221.13 GiB (100.00%)
ID-4: /var/log raw-size: 221.13 GiB size: 221.13 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.13 GiB size: 221.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.49 GiB used: 555 MiB (3.5%) priority: 100
ID-2: swap-2 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 61.0 C pch: 62.0 C mobo: N/A
Memory: total: 16 GiB available: 15.49 GiB used: 4.13 GiB (26.6%)
Processes: 328 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1605 libs: 444 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-15
Last full system update: 2024-02-16 ↻
