Good Evening Guys..
I have been facing a strange issue with BSPWM (in all distro, i have notified in every forum looking for any suggestion). I'm facing a HiDPI issue in a very random yet unusual way.. after recent update iin archlinux ny configs are working as random HiDPI issue, such as conky lxappearance virtualbox kdenlive etc.. I'm having this issue in Garuda also..
i checked my scaling but it was 1x with 1920x1080 res so i guess it is ok. couldn't figureout what is the issue.. If anyone faced such issue... please suggest my how to solve..
SGS
11 November 2021 16:26
#2
Post your inxi as it was described in the template, please.
Otherwise, I will close here.
System: Kernel: 5.15.1-216-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=11ff69ae-b2c6-451b-af69-059c17893db1 rw [email protected] loglevel=3 quiet
Desktop: N/A vt: 7 dm: LightDM 1.30.0 Distro: Arch Linux
Machine: Type: Laptop System: HP product: HP Laptop 15-bs1xx v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 832B v: 23.78 serial: <filter> UEFI: Insyde v: F.65 date: 12/06/2019
Battery: ID-1: BAT1 charge: 0% condition: 25.3/41.4 Wh (61.0%) volts: 11.2 min: 14.8 model: Hewlett-Packard PABAS0241231
type: Li-ion serial: <filter> status: Unknown
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28824
Speed: 3400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3400 2: 3400 3: 3400 4: 3400 5: 2835 6: 2600 7: 3400
8: 3400
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Display: x11 server: X.Org 1.21.1.1 compositor: picom v: git-dac85 driver: loaded: intel,modesetting unloaded: vesa
alternate: ati,fbdev display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.1-216-tkg-bmq running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_8723de v: N/A
modules: rtw88_8723de port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:d723 class-ID: 0280
Bluetooth: Device-1: Realtek 802.11n WLAN Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-4:5 chip-ID: 0bda:b009
Drives: Local Storage: total: 938.97 GiB used: 22.96 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade size: 7.45 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.27 scheme: MBR
Partition: ID-1: / raw-size: 930.22 GiB size: 930.22 GiB (100.00%) used: 22.96 GiB (2.5%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 930.22 GiB size: 930.22 GiB (100.00%) used: 22.96 GiB (2.5%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
Swap: Kernel: swappiness: 20 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 1024 MiB used: 780 KiB (0.1%) priority: -2 dev: /dev/sda2 maj-min: 8:2
Sensors: System Temperatures: cpu: 68.0 C mobo: 29.8 C gpu: radeon temp: 39.0 C
Info: Processes: 255 Uptime: 4m wakeups: 1 Memory: 7.56 GiB used: 2.35 GiB (31.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1319 lib: 324 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: kitty inxi: 3.3.08
SGS
13 November 2021 13:29
#5
Check the cables.
Check other DE's too. KDE, Xfce ...
only in BSPWM ... i tried other DEs and WMs... but only BSPWM has this issue in all distros in my laptop as well as on VMs too... this happened after recent update..
