I’ve recently installed Garuda Linux Dr460nized edition.
The system comes with many packages and apps I don’t require, but are essential to the system.
For example, Avahi SSH Browser is of no use to me. However, it is required by the system. I tried removing the Avahi package from Octopi, but it removed so many other important dependencies that I had to reinstall Garuda. Is there any way that I can hide the app from appearing in the Application launcher but is not removed or uninstalled.
Welcome to the forum
Please always post your garuda-inxi
when asking for help in the Issues & Assistance category.
Please, do not use octopi
to install/uninstall packages. Please always use pacman
in the terminal for this.
Also KDE:
Right click on the Application Launcher → Edit Applications.
In the KDE Menu Editor, select the corresponding entry on the left side and press “Delete” in the menu bar, then click “Save”.
Edit: If you don’t want to delete the entries, you can simply create a new submenu yourself and move (cut/paste) everything you don’t need there, for example:
Thankyou very much!
