Issue: I want to understand how hibernate is supposed to be initiated.
Description: I installed garuda sway and with hibernate enabled. hibernate does work well but i was wondering exactly how to use it. I know i could just run “systemctl hibernate” but that seems counter intuitive especially with the presence of nwgbar.
nwgbar has a suspend option which seems to work like sleep. I had gone through a similar post, the op had posted his /etc/systemd/sleep.conf file and he had some parts commented out. Right now, i think suspend also lead to hibernation depending on the sleep.conf but I have not found anything to confirm this line of thought. I am wondering if there is a reason that a hibernate option is not added by default to nwgbar or if i missed something along the way.
Present workaround: what i have done for the mean time is modify what remove the suspend option and add a hibernate option that runs “systemctl hibernate”
Kernel: 6.10.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=484dd57a-5f67-40db-ab5f-2140b1215e18 rw rootflags=subvol=@
quiet resume=UUID=ded305a3-d141-4206-9cb8-a3535afadfb9 loglevel=3 ibt=off
Desktop: Sway v: 0.4 with: waybar tools: swayidle avail: swaylock
lm: greetd Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 840 G7 Notebook PC v: SBKPF
Mobo: HP model: 8723 v: KBC Version 06.4A.00 serial: <filter>
part-nu: 1D0F2UT#ABA uuid: a88509b5-37b8-40fb-b9f5-d25840f408f0 UEFI: HP
v: S70 Ver. 01.17.00 date: 04/12/2024
ID-1: BAT0 charge: 44.1 Wh (96.5%) condition: 45.7/53.2 Wh (85.9%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 161
Info: model: Intel Core i7-10810U socket: BGA1510 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet Lake gen: core 10 level: v3 note: check
built: 2020 process: Intel 14nm family: 6 model-id: 0xA6 (166) stepping: 0
microcode: 0xFE
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 441 high: 900 min/max: 400/4900 base/boost: 990/4900
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 900 bogomips: 38399
Device-1: Intel Comet Lake UHD Graphics vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bca class-ID: 0300
Device-2: Luxvisions Innotech HP HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 30c9:000f
Display: wayland server: Xwayland v: 24.1.2 compositor: Sway v: 0.4
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0x068b built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0401
API: ALSA v: k6.10.8-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 10.79 GiB (2.3%)
model: MZVLB512HBJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS0NEXF temp: 33.9 C scheme: GPT
ID-1: / raw-size: 460.18 GiB size: 460.18 GiB (100.00%)
used: 10.79 GiB (2.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 460.18 GiB size: 460.18 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 460.18 GiB size: 460.18 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 460.18 GiB size: 460.18 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 14.97 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.46 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 40.0 C pch: 41.0 C mobo: N/A
Memory: total: 16 GiB available: 14.97 GiB used: 1.21 GiB (8.1%)
igpu: 512 MiB
Processes: 292 Power: uptime: 4h 59m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 5.98 GiB
services: power-profiles-daemon Init: systemd v: 256 default: graphical
Packages: pm: pacman pkgs: 1320 libs: 413 tools: pacseek,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
running-in: foot inxi: 3.3.35
System install date: 2024-09-07
Last full system update: 2024-09-08
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it under the
# terms of the GNU Lesser General Public License as published by the Free
# Software Foundation; either version 2.1 of the License, or (at your option)
# any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file (or a copy of it placed in
# /etc/ if the original file is shipped in /usr/), or by creating "drop-ins" in
# the /etc/systemd/sleep.conf.d/ directory. The latter is generally
# recommended. Defaults can be restored by simply deleting the main
# configuration file and all drop-ins located in /etc/.
# Use 'systemd-analyze cat-config systemd/sleep.conf' to display the full config.
# See systemd-sleep.conf(5) for details.
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#MemorySleepMode=
#HibernateDelaySec=
#SuspendEstimationSec=60min
