Hibernation issue
Sleep works, I’d like to ask for an easy way to enable Hibernation. I have 2 other OS installed before installing garuda linux, so maybe that is the reason hibernation doesn’t show by default
Garuda-inxi:
.%;888:8898898:                honzak@jan-21kr
x;XxXB%89b8:b8%b88:              ---------------
.8Xxd                8X:.           OS: Garuda Linux x86_64
.8Xx;                    8x:.         Host: 21KR (ThinkBook 13x G4 IMH)
.tt8x          .d            x88;       Kernel: 6.14.4-zen1-2-zen
.@8x8;          .db:              xx@;     Uptime: 11 mins
,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;    Packages: 2206 (pacman)[stable]
.SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;    Shell: fish 4.0.2
,888S                                     pd!    Resolution: 2880x1920
8X88/                                       q     DE: KDE Plasma 6.3.4
8X88/                                             WM: KWin (Wayland)
GBB.                                              WM Theme: Sweet-Dark
x%88        d888@8@X@X@X88X@@XX@@X@8@X.          Theme: Dr460nized (Sweet) [Qt], Sweet-Dark [GTK2/3/4]
dxXd    dB8b8b8B8B08bB88b998888b88x.           Icons: BeautyLine [Qt], BeautyLine [GTK2/3/4]
dxx8o                      .@@;.              Terminal: konsole 25.4.0
dx88                   .t@x.                Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad.                  CPU: Intel(R) Core(TM) Ultra 9 185H (22) @ 5.10 GHz
.d988999889889899dd.                    GPU: Intel Arc Graphics @ 2.35 GHz [Integrated]
Memory: 5408 MiB / 31691 MiB
╭─honzak@jan in ~
╰─λ garuda-inxi
Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=00c0f128-ec21-4613-9c7c-62554e481259 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 21KR v: ThinkBook 13x G4 IMH
serial: <superuser required> Chassis: type: 10 v: ThinkBook 13x G4 IMH
Mobo: LENOVO model: LNVNB161216 v: SDK0T76528 WIN
serial: <superuser required> part-nu: LENOVO_MT_21KR_BU_idea_FM_ThinkBook
13x G4 IMH uuid: <superuser required> UEFI: LENOVO v: MTCN50WW
date: 12/25/2024
ID-1: BAT1 charge: 73.0 Wh (97.1%) condition: 75.2/74.0 Wh (101.7%)
power: 11.8 W volts: 17.5 min: 15.6 model: Simplo BASE-BAT type: Li-poly
serial: <filter> status: discharging cycles: 3
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1992 min/max: 400/4800:5100:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1992 2: 1992 3: 1992
4: 1992 5: 1992 6: 1992 7: 1992 8: 1992 9: 1992 10: 1992 11: 1992 12: 1992
13: 1992 14: 1992 15: 1992 16: 1992 17: 1992 18: 1992 19: 1992 20: 1992
21: 1992 22: 1992 bogomips: 135168
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Monitor-1: eDP-1 model: California Institute of eDP-1-0x1319 built: 2023
res: mode: 2880x1920 hz: 60 scale: 200% (2) to: 1440x960 dpi: 257 gamma: 1.2
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2880x1920
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 15.11 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: integrated-gpu name: Intel
Arc Graphics (MTL) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:7d55 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
Device-1: Intel Meteor Lake IPU vendor: Lenovo driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 00:05.0 chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 953.87 GiB used: 29.01 GiB (3.0%)
model: MZAL81T0HDLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 6L1QKXD7 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 130.34 GiB size: 130.34 GiB (100.00%)
used: 28.94 GiB (22.2%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
used: 70.1 MiB (27.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 130.34 GiB size: 130.34 GiB (100.00%)
ID-4: /var/log raw-size: 130.34 GiB size: 130.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 130.34 GiB size: 130.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.95 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 22
Src: /sys System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.95 GiB used: 5.35 GiB (17.3%)
Processes: 490 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 12.36 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 2206 libs: 616
tools: gnome-software,octopi,paru Compilers: clang: 19.1.7 gcc: 15.1.1
Shell: garuda-inxi default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date:     2025-05-03
Last full system update: 2025-05-03 ↻
╭─honzak@jan in ~ took 2s
╰─λ
This article should include the info you need:
For the resume processi, we use dracut instead of mkinitcpio like in the wiki, so you could refer to this solution:
Check if it is shown after a reboot.
It looks like you have not configued a swap file to hibernate to yet (only the zram device is shown here).
