Hi,
I just created SWAP file on a non-compressed, non-snapshotted subvolume as Archwiki suggested.
I'm not sure that I miss something.
Do I have to do something with grub, initrams, timeshift...etc ?
Any help/suggestions would be greatly appreciated.
What I did and How I did:
sda 8:0 0 931,5G disk
├─sda1 8:1 0 300M part FAT32 EFI
├─sda2 8:2 0 530,7G part BTRFS /root
├─sda3 8:3 0 16M part UNKWN Microsoft Reserved
└─sda4 8:4 0 307,4G part NTFS Win10
1.Mount sda2
sudo mount /dev/sda2 /mnt
2.Create a new @swap subvolume
sudo btrfs subvolume create /mnt/@swap
3.Unmount sda2
sudo umount /mnt
4.Create /swap directory where I plan to mount the @swap subvolume.
sudo mkdir /swap
5.Mount the @swap subvolume to /swap.
sudo mount -o subvol=@swap /dev/sda2 /swap
6.Create swap file 16 GB.
sudo touch /swap/swapfile
sudo chattr +C /swap/swapfile
sudo truncate -s 0 /swap/swapfile
sudo fallocate -l 16000M /swap/swapfile
sudo chmod 600 /swap/swapfile
sudo mkswap /swap/swapfile
Setting up swapspace version 1, size = 15,6 GiB (16777211904 bytes)
no label, UUID=71462731-7564-424d-9cf2-1d8b69133db6
7.Turn the swap file on.
sudo swapon /swap/swapfile
8.Update /etc/fstab to mount all this on boot. Add there two lines:
UUID=2D32-43BF /boot/efi vfat umask=0077 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b / btrfs subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 1
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /home btrfs subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /root btrfs subvol=@root,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /srv btrfs subvol=@srv,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /var/cache btrfs subvol=@cache,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /var/log btrfs subvol=@log,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /var/tmp btrfs subvol=@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b /swap btrfs defaults,noatime,subvol=@swap 0 0
/swap/swapfile none swap sw 0 0
