Help with polybar in Garuda Mokka
Hello, I have a problem when expanding a window to full screen. When I do this, stripes appear on the top taskbar. Does anyone know how to solve this?
garuda-inxi:
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=080dbbdf-71dc-4a93-b8e4-7750f48628d5 rw rootflags=subvol=@
Type: Desktop Mobo: JINGSHA model: B75-HM PLUS serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: 4.6.5
date: 01/31/2023
Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
Speed (MHz): avg: 2399 min/max: 1600/3900 scaling: driver: intel_cpufreq
governor: performance cores: 1: 2399 2: 2399 3: 2399 4: 2399 5: 2399 6: 2399
7: 2399 8: 2399 bogomips: 55871
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 570.124.04 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,DVI-D-2 empty: DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
d-rect: 3360x1980 display-ID: 0
Monitor-1: DP-1 pos: primary,top-left model: A24FAA-RG serial: <filter>
built: 2023 res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DVI-D-2 pos: bottom-r model: Samsung SyncMaster
serial: <filter> built: 2007 res: mode: 1440x900 hz: 75 scale: 100% (1)
dpi: 89 gamma: 1.35 size: 410x257mm (16.14x10.12") diag: 484mm (19.1")
ratio: 16:10 modes: max: 1440x900 min: 640x480
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.124.04 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: N/A device-ID: 10de:1c82
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api with: aoss
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.6:3
Local Storage: total: 2.41 TiB used: 18.37 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3.2.J.F0 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
serial: <filter> fw-rev: .20 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM014-1EJ164
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: SM14 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST9500423AS
tech: HDD rpm: 7200 serial: <filter> fw-rev: DEM1 scheme: GPT
ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 18.37 GiB (16.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.71 GiB used: 728.6 MiB (9.2%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 48.0 C mobo: N/A
Memory: total: 8 GiB available: 7.71 GiB used: 5.55 GiB (71.9%)
Processes: 305 Power: uptime: 1h 39m states: freeze,standby,mem,disk
suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 3.02 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1443 libs: 409 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-17
Last full system update: 2025-03-17 ↻
P.S I’m talking about the one that defaults to
