Help with Octopi and AUR
Hi guys
I am quite new to the Arch linux userspace. I love using the AUR and use it regularly with the PAMAC installer.
The default installer for Garuda is Octopi and I like it and love the layout of it but I don't know how to use it to install programs from the AUR. I click the Alien head and search for the program, I them click install.
This then opens up the mini terminal at the bottom of the screen.
I then press enter to proceed to the review and it downloads the PKGBUILDs but I don't know what to do from there?
I'm sure there is a step I am missing and I'm just being a fool.
Any help is greatly appreciated.
Kind regards
Josh
From Octopi's settings you need to enable AUR, then you can install/update AUR packages.
Hi Sammiev
Here is what my settings look like in Octopi:
Alacritty encountered an unrecoverable error:
Kind regards
Josh
If you are using paru, you may have to press q when the PKGBUILD shows up.
If it is something else, you need to show us what you are actually seeing.
I would install yay then enable the AUR in Octopi's settings
Dalto!
You legend!
That is exactly it. All fixed.
Is that a feature exclusive to Paru?
I wasn't sure whether it was an Octopi thing or the AUR helper which was stopping me.
@Bro I will consider installing yay if I have anymore issues.
Thank you everybody fro your help.
Kind regards
Josh
It isn't exclusive to paru but it is the default in paru.
If you switch to yay, I don't think that will happen but I haven't used octopi in years so I can't say for sure.
Thanks Dalto.
I will continue to use Paru. I have found it’s documentation on the GitHub page and will have a read.
Which octopi version are you using? Recently a new update which also featured fixes for paru got released :slight_smile:
