Hi!
I think i mixed something with Garuda Boot Options, because my Plymouth boot is not silent anymore.
Would someone be as kind to share with me the correct boot parameters ?
This is how my parameters are looks now:
quiet splash loglevel=3 rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 sysrq_always_enabled=1 mitigations=off
Sysinfo
─λ inxi -Fxxxza
System: Kernel: 5.10.13-118-tkg-pds x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds-nehalem
root=UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b rw rootflags=subvol=@ quiet splash loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP EliteBook 8540p v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 1521 v: KBC Version 32.36 serial: <filter> UEFI: Hewlett-Packard
v: 68CVD Ver. F.60 date: 11/11/2015
Battery: ID-1: BAT0 charge: 59.0 Wh condition: 59.0/59.0 Wh (100%) volts: 16.3/14.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7 Q 840 bits: 64 type: MT MCP arch: Nehalem family: 6
model-id: 1E (30) stepping: 5 microcode: A L2 cache: 8 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29828
Speed: 2806 MHz min/max: 1199/1867 MHz boost: enabled Core speeds (MHz): 1: 2806 2: 2698 3: 1731
4: 2004 5: 2769 6: 2926 7: 2284 8: 3301
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Graphics: Device-1: NVIDIA GF106GLM [Quadro 2000M] vendor: Hewlett-Packard driver: nvidia v: 390.138
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:0dda class ID: 0300
Device-2: Chicony HP Webcam [2 MP Macro] type: USB driver: uvcvideo bus ID: 1-1.5:5
chip ID: 04f2:b15e class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia display ID: :0
Screen-1: 0 s-res: 1366x768 s-dpi: 102 s-size: 340x191mm (13.4x7.5") s-diag: 390mm (15.4")
Monitor-1: LVDS-0 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Quadro 2000M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.138 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56 class ID: 0403
Device-2: NVIDIA GF106 High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0be9 class ID: 0403
Sound Server: ALSA v: k5.10.13-118-tkg-pds
Network: Device-1: Intel 82577LM Gigabit Network vendor: Hewlett-Packard driver: e1000e v: kernel
port: 6020 bus ID: 00:19.0 chip ID: 8086:10ea class ID: 0200
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel port: 5000 bus ID: 44:00.0
chip ID: 8086:4239 class ID: 0280
Bluetooth: Device-1: HP Broadcom 2070 Bluetooth Combo type: USB driver: btusb v: 0.8 bus ID: 1-1.1:3
chip ID: 03f0:231d class ID: fe01
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 931.51 GiB used: 39.83 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 023
Partition: ID-1: / raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 39.81 GiB (7.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 25.8 MiB (8.6%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 39.81 GiB (7.5%) fs: btrfs
ID-4: /var/log raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 39.81 GiB (7.5%) fs: btrfs
ID-5: /var/tmp raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 39.81 GiB (7.5%) fs: btrfs
ID-1: swap-1 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 979.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 67.0 C mobo: 0.0 C gpu: nvidia temp: 55 C
Info: Processes: 260 Uptime: 3h 59m wakeups: 2 Memory: 7.65 GiB used: 3.93 GiB (51.3%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1589 lib: 488 Shell: fish v: 3.1.2
running in: konsole inxi: 3.3.00
