Help with hibernation / zram conflict
Hello Comunity.
First of all thank you for this great linux distribution. Everything works great.
I haven't been able to make hibernation work. I understand that zram (which comes by default in garuda) conflicts with hibernation.
To reach this I think I need to disable zram, which I think I disabled by:
sudo systemctl stop /dev/zram0
running swapon shows only my disk swap:
NAME           TYPE       SIZE   USED PRIO
/dev/nvme0n1p4 partition 15,6G 664,3M   -2
Hibernation seems to work (save RAM data to disk), but when boot again, system boots into a fresh / new session, not previous / saved session.
Below is my garuda-inxi.
Any help / clarification is highly appreciated.
  Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=b5bba6b0-160e-4711-833f-21731ba61ab4 rw rootflags=subvol=@
  Type: Laptop System: HP product: HP ZBook Firefly 14 inch G8 Mobile
    Workstation PC v: N/A serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 880D v: KBC Version 30.37.00 serial: <superuser required>
    UEFI: HP v: T76 Ver. 01.08.00 date: 01/11/2022
  ID-1: BAT0 charge: 39.8 Wh (99.0%) condition: 40.2/53.2 Wh (75.6%)
    volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: not charging cycles: 130
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    microcode: 0xAA
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 3060 high: 4300 min/max: 400/4700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3100 2: 2800 3: 4300
    4: 3795 5: 3936 6: 843 7: 3652 8: 2061 bogomips: 44851
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA TU117GLM [Quadro T500 Mobile] vendor: Hewlett-Packard
    driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 4 speed: 16 GT/s lanes: 4
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1fbb class-ID: 0302
  Device-3: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 04f2:b6bf
  Monitor-1: eDP-1 model: AU Optronics 0x559c built: 2021 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 275.97 GiB (57.9%)
    model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: HPS2NGXH temp: 40.9 C scheme: MBR
  ID-1: / raw-size: 62.7 GiB size: 62.7 GiB (100.00%) used: 20.64 GiB (32.9%)
  ID-3: /home raw-size: 398.32 GiB size: 391 GiB (98.16%)
    used: 254.96 GiB (65.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 62.7 GiB size: 62.7 GiB (100.00%)
    used: 20.64 GiB (32.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-5: /var/tmp raw-size: 62.7 GiB size: 62.7 GiB (100.00%)
  ID-1: swap-1 type: partition size: 15.62 GiB used: 377.5 MiB (2.4%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 58.0 C mobo: N/A
  Processes: 264 Uptime: 5m wakeups: 17798 Memory: available: 15.31 GiB
  used: 4.85 GiB (31.7%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1576 libs: 427 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.1
  running-in: konsole inxi: 3.3.27
  System install date:     2023-07-08
  Last full system update: 2023-07-09
  Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
Hi there, welcome to the forum!
First off, but not cause of your issue, you don’t need to disable zram. You will only loose a bit of performance. For sure you can’t use zram to hibernate on, you use your swap partition.
The first thing you seem to be missing is the resume kernel boot parameter, pointing to your swap partition.
Then you’ll need a dracut config.
I’m linking below a somewhat similar thread for zram and dracut. The kernel parameter should not be a problem of course.
If necessary, see also the Arch wiki.
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Hibernation
Careful, the initramfs part for you is different because you have dracut instead of mkinitcpio.
https://wiki.archlinux.org/title/Dracut#Hibernation
Then regenerate with
sudo dracut-rebuild
Thanks, very clear
Worked perfectly !
