I am running dragonized gamer verson of garuda.
So I am having a hard time setting up an extended desktop on dual monitors. I have two monitors, the same, 1920x1080 res. Yeah they work just fine in dual monitor mode, but i have a situation where i need computer to recognize both monitors as a single display.
I read the arch wiki, multihead and extreme multihead with xrandr, but that does not work. I have read that there might be a way to do a virtual desktop? Like with amd eyefinity? I dont see any AUR or anything for an app that supports this.
Any ideas?
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ad282eb0-5061-458a-b805-03b1355aa6c2 rw rootflags=subvol=@
Mobo: ASUSTeK model: ProArt X570-CREATOR WIFI v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0402
date: 08/04/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 2 microcode: 0xA201204
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3425 high: 3811 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3593 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400
20: 3400 21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400
28: 3400 29: 3400 30: 3599 31: 3811 32: 3400 bogomips: 217200
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASRock
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0c:00.0 chip-ID: 1002:73ff
s-diag: 1052mm (41.43")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left model: Gigabyte
G27FC A serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: HP 27 Curved
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6600 XT (dimgrey_cavefish LLVM 14.0.6 DRM
3.47 5.19.4-zen1-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
Device-1: Aquantia AQC113CS NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK ProArt X570-CREATOR WIFI driver: atlantic v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 2 port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:94c0 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Supported mdraid levels: raid10
Device-1: md10 maj-min: 9:10 type: mdraid level: raid-10 status: active
Info: report: 4/4 UUUU blocks: 312581120 chunk-size: 512K
super-blocks: 1.0
Components: Online:
0: sda maj-min: 8:0 size: 149.05 GiB
1: sdb maj-min: 8:16 size: 149.05 GiB
2: sdc maj-min: 8:32 size: 149.05 GiB
3: sdd maj-min: 8:48 size: 149.05 GiB
Local Storage: total: 1.04 TiB used: 629.78 GiB (59.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: BarraCuda Q5
ZP500CV30001 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: SU5SH018
temp: 35.9 C scheme: GPT
model: WD1600ADFD-60NLR5 size: 149.05 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter> rev: 7QR5
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 347.41 GiB
(74.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 347.41
GiB (74.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 347.41
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 347.41
ID-1: swap-1 type: zram size: 62.69 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: 35.0 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 0 gpu: amdgpu fan: 0
Processes: 532 Uptime: 16h 21m wakeups: 0 Memory: 62.69 GiB used: 5.59 GiB
(8.9%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 2037 pacman: 2031 lib: 541 flatpak: 6
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-03-05
Last full system update: 2022-08-28
Failed units: mdmonitor.service
