Help with drivers for amd gpu
no i have not tryed to do a update after the mix up. nervous that i wrecked it but i have games running and full use again but just don’t want to re do my computer.
this is my Garuda-inxi
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=65743ce1-7229-4480-ac26-54bec464f9aa rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: LENOVO product: 11A9000UUS v: ThinkCentre M75s-1
Mobo: LENOVO model: 3148 v: SDK0J40697 WIN 3305330116396
part-nu: LENOVO_MT_11A9_BU_Think_FM_ThinkCentre M75s-1
uuid: <superuser required> UEFI: LENOVO v: M2CKT38A date: 08/24/2020
Info: model: AMD Ryzen 5 PRO 3400G with Radeon Vega Graphics bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3143 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 3143 2: 3143 3: 3143
4: 3143 5: 3143 6: 3143 7: 3143 8: 3143 bogomips: 59200
Device-1: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon
540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports: active: DP-1,HDMI-A-1 empty: none
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 63.0 C
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-2,DP-3,DP-4
bus-ID: 0e:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 51.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu,amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
(radeonsi polaris12 LLVM 18.1.8 DRM 3.59 6.12.1-zen1-1-zen)
device-ID: 1002:699f memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 16 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
v: 24.2.7-arch1.1 device-ID: 1002:699f surfaces: xcb,xlib,wayland
device: 1 type: integrated-gpu name: AMD Radeon Vega 11 Graphics (RADV
RAVEN) driver: mesa radv v: 24.2.7-arch1.1 device-ID: 1002:15d8
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8)
Device-1: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX
550 640SP / 560/560X] driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Lenovo driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
bus-ID: 0e:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Generalplus USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 1b3f:2008 class-ID: 0300
Device-6: Generic USB SPDIF Adapter
lanes: 1 mode: 1.1 bus-ID: 4-3:3 chip-ID: 4e5b:4032 class-ID: 0300
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
port: ec00 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 0a5c:21e8
Local Storage: total: 1.84 TiB used: 1.64 TiB (89.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T2531TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
used: 825.8 GiB (88.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 37.13 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.5 C mobo: N/A
GPU: device: amdgpu temp: 51.0 C device: amdgpu temp: 63.0 C watts: 15.19
Memory: total: 40 GiB note: est. available: 37.13 GiB used: 6.16 GiB (16.6%)
Processes: 371 Power: uptime: 13h 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 14.84 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2099 libs: 586
tools: gnome-software,octopi,paru Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-07-20
Last full system update: 2024-12-04
24.2.7 is the version of mesa you are using. Whatever you are looking at on the AMD website is unrelated.
There was a bug with the 24.3.1 version of mesa affecting certain AMD GPUs. See this related topic from another forum:
The issue is resolved with mesa 24.3.1-2, which is already in the stable repo. Updating normally should resolve the issue.
