Trying to run the conky seamod with rings. I had it working at one time but I don’t remember what I had to do to get rings working.
I thought it was just lua and cairo, but can’t figure it out.
Garuda inxi
Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=89e14150-63d0-465e-b482-78134e6232b9 rw rootflags=subvol=@
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.43 wm: Muffin v: 6.2.0 tools:
avail: cinnamon-screensaver,xautolock dm: LightDM v: 1.32.0 Distro: Garuda
Type: Desktop System: Dell product: Inspiron 3670 v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Dell model: 0H4VK7 v: A01 serial: <filter> part-nu: 0868
uuid: 4c4c4544-0047-4810-8036-c2c04f315332 UEFI: Dell v: 2.21.0
date: 12/03/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: Intel Core i5-9600K socket: LGA1151 (U3E1) note: check bits: 64
type: MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xC (12)
microcode: 0xF8
desc: 1x9 MiB
Speed (MHz): avg: 816 high: 900 min/max: 800/4600 base/boost: 3663/4300
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 900 4: 800 5: 800 6: 800
bogomips: 44398
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
ports: active: none empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0380
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
s-diag: 687mm (27.05")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
serial: <filter> built: 2022 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.295 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 560.35.03
device-ID: 10de:1d01 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 24.2.2-arch1.1 device-ID: 8086:3e98 surfaces: xcb,xlib device: 2
v: 24.2.2-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: n/a (root, process) with:
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 2.73 TiB used: 681.19 GiB (24.4%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 24.9 C scheme: GPT
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
ID-1: / raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
used: 13.45 GiB (2.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 27 MiB (28.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 31.17 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 26.0 C pch: 29.0 C mobo: 24.0 C gpu: nvidia
temp: 32 C
Fan Speeds (rpm): fan-1: 986 gpu: nvidia fan: 32%
Memory: total: 32 GiB available: 31.17 GiB used: 2.04 GiB (6.5%)
Processes: 280 Power: uptime: 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: csd-power,upowerd
Packages: 1470 pm: pacman pkgs: 1463 libs: 412 tools: pamac,paru
pm: flatpak pkgs: 7 Compilers: gcc: 14.2.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.32 running-in: gnome-terminal inxi: 3.3.35
System install date: 2024-09-10
Last full system update: 2024-09-11
Windows dual boot: Yes
Failed units: none
conky version
conky -v
conky 1.21.6-pre-fc8fe76 compiled for Linux x86_64
Compiled in features:
System config file: /etc/conky/conky.conf
Package library path: /usr/lib/conky
General:
* math
* hddtemp
* portmon
* IPv6
* Curl
* RSS
* wireless
* support for IBM/Lenovo notebooks
* nvidia
* builtin default configuration
* old configuration syntax
* Imlib2
* OSS mixer support
* apcupsd
* iostats
* ncurses
* Internationalization support
* PulseAudio
Lua bindings:
* Cairo
* Imlib2
* RSVG
X11:
* Xdamage extension
* Xinerama extension (virtual display)
* Xshape extension (click through)
* XDBE (double buffer extension)
* Xft
* ARGB visual
* Own window
* Mouse events
Wayland:
* ARGB visual
* Mouse events
Music detection:
* CMUS
* MPD
* MOC
Default values:
* Netdevice: eno1
* Local configfile: $HOME/.conkyrc
* Localedir: /usr/share/locale
* Maximum netdevices: 256
* Maximum text size: 16384
* Size text buffer: 256
conky-manager version 2.4
My conky-seamod config
# conkyrc_seamod
# Date : 05/02/2012
# Author : SeaJey
# Version : v0.1
# License : Distributed under the terms of GNU GPL version 2 or later
# This version is a modification of conkyrc_lunatico wich is modification of conkyrc_orange
# conkyrc_orange: http://gnome-look.org/content/show.php?content=137503&forumpage=0
# conkyrc_lunatico: http://gnome-look.org/content/show.php?content=142884
background no
update_interval 1
cpu_avg_samples 1
net_avg_samples 2
temperature_unit fahrenheit
double_buffer yes
no_buffers yes
text_buffer_size 2048
gap_x 20
gap_y 30
minimum_size 300 900
maximum_width 400
own_window yes
own_window_type desktop
own_window_transparent yes
own_window_argb_visual yes
own_window_colour 000000
own_window_argb_value 0
own_window_hints undecorate,sticky,skip_taskbar,skip_pager,below
border_inner_margin 0
border_outer_margin 0
alignment top_right
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
override_utf8_locale yes
use_xft yes
xftfont caviar dreams:size=10
xftalpha 0.5
uppercase no
# Defining colors
default_color FFFFFF
# Shades of Gray
color1 DDDDDD
color2 AAAAAA
color3 888888
# Orange
color4 EF5A29
# Green
color5 77B753
# Loading lua script for drawning rings
lua_load /home/keith/.seamod_rings.lua
lua_draw_hook_post main
## System information using conky capabilities
# Header with base system info
#own_window_argb_value 0
#own_window_colour 000000
TEXT
${font Ubuntu:size=10,weight:bold}${color4}SYSTEM ${hr 2}
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}$sysname $kernel $machine
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}$nodename
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}Logged In: $USER
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}Uptime: $uptime
# Showing CPU Graph
${voffset 20}
${offset 120}${cpugraph 40,183 666666 666666}${voffset -25}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}CPU
# Showing TOP 5 CPU-consumers
${offset 105}${font Ubuntu:size=10,weight:normal}${color4}${top name 1}${alignr}${top cpu 1}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color1}${top name 2}${alignr}${top cpu 2}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color2}${top name 3}${alignr}${top cpu 3}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top name 4}${alignr}${top cpu 4}%
#${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top name 5}${alignr}${top cpu 5}%
#Showing memory part with TOP 5
${voffset 20}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}MEM
${offset 105}${font Ubuntu:size=10,weight:normal}${color4}${top_mem name 1}${alignr}${top_mem mem 1}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color1}${top_mem name 2}${alignr}${top_mem mem 2}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color2}${top_mem name 3}${alignr}${top_mem mem 3}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top_mem name 4}${alignr}${top_mem mem 4}%
#${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top_mem name 4}${alignr}${top_mem mem 5}%
# Showing disk partitions: root, home and Data
${voffset 20}
${offset 120}${diskiograph 20,183 666666 666666}${voffset -25}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}DISKS
#${voffset 20}
${offset 15}${font Ubuntu:size=9,weight:bold}${color1}SDA: ${font Ubuntu:size=9,weight:normal}${fs_free /}${alignr}${font Ubuntu:size=9,weight:bold}Used: ${font Ubuntu:size=9,weight:normal}${fs_used /}
${offset 15}${font Ubuntu:size=9,weight:bold}${color1}Storage: ${font Ubuntu:size=9,weight:normal}${fs_free /mnt/storage1}${alignr}${font Ubuntu:size=9,weight:bold}Used: ${font Ubuntu:size=9,weight:normal}${fs_used /mnt/storage1}
# Network data (my desktop have only LAN). ETHERNET ring is mostly useless but looks pretty, main info is in the graphs
${voffset 43}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}ETHERNET
${voffset 20}
${offset 15}${color1}${font Ubuntu:size=9,weight:bold}Up: ${alignr}${font Ubuntu:size=9,weight:normal}$color2${upspeed enp3s0} / ${totalup}
${offset 15}${upspeedgraph enp3s0 20,285 4B1B0C FF5C2B 100 -l}
${offset 15}${color1}${font Ubuntu:size=9,weight:bold}Down: ${alignr}${font Ubuntu:size=9,weight:normal}$color2${downspeed enp3s0} / ${totaldown}
${offset 15}${downspeedgraph enp3s0 20,285 324D23 77B753}
${voffset 15}${font Ubuntu:size=10,weight:bold}${color5}ADDRESS:${voffset 5}${font}
${color1}Wan: ${execi 3600 wget -q -O - checkip.dyndns.org | sed -e 's/[^[:digit:]\|.]//g'}
Lan: ${addr enp3s0}
Inbound Ports: ${tcp_portmon 1 32767 count}
Outbound Ports: ${tcp_portmon 32768 61000 count}
${color4}${hr 2}
Any help or pointers would be appreciated.
