Help with ASUS G14
Heya, just made an account on the forum. Been chasing this issue for days now, still pretty new to Linux as a whole.
So I have an ASUS ROG G14 (GA402NU) equipped with a Ryzen 7 7735hs, and an rtx 4050 mobile. I have the current Nvidia proprietary driver installed, but i’m not sure if it’s working? Trying to boot games and it only allows a max of 720p, the screen is a 165hz 1600p panel.
I’m not sure what from the inxi y’all would need but here’s what comes up when I run it.
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 14.2.1 clocksource: tsc avail: acpi_pm
root=UUID=a36210bf-fb99-4e4f-8d06-c92f4cbdbd80 rw
rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A
info: frameworks v: 6.5.0 wm: kwin_wayland vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14
GA402NU_GA402NU v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA402NU v: 1.0
UEFI: American Megatrends LLC. v: GA402NU.318
date: 04/22/2024
ID-1: BAT0 charge: 34.3 Wh (47.9%)
condition: 71.6/76.0 Wh (94.2%) power: 26.7 W volts: 14.8
min: 15.9 model: AS3GXPe3KC GA40249 type: Unknown
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics
bits: 64 type: MT MCP arch: Zen 3+ gen: 4 level: v3
note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16
smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2096 high: 3169 min/max: 400/4829
scaling: driver: amd-pstate-epp governor: performance
cores: 1: 3168 2: 3167 3: 2925 4: 400 5: 2880 6: 400
7: 3168 8: 3167 9: 3169 10: 400 11: 3168 12: 400
13: 3166 14: 400 15: 3169 16: 400 bogomips: 102212
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 sse4a ssse3 svm
Device-1: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: ASUSTeK driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 8 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:28e1 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-2
empty: DP-2, DP-3, DP-4, DP-5, DP-6, Writeback-1
bus-ID: 75:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 39.0 C
Use prime-run like here:
In case of graphical troubles try also selecting and x11 session in the login screen.
Welcome :slight_smile:
We need all, and you post just a part :wink:
Understood! I’ll update it tonight with the full list. My bad!
Okay, sorry I am just now able to grab it.
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a36210bf-fb99-4e4f-8d06-c92f4cbdbd80 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402NU_GA402NU
Mobo: ASUSTeK model: GA402NU v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GA402NU.318
date: 04/22/2024
ID-1: BAT0 charge: 7.9 Wh (11.0%) condition: 71.6/76.0 Wh (94.2%)
power: 77.1 W volts: 16.3 min: 15.9 model: AS3GXPe3KC GA40249 type: Unknown
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Speed (MHz): avg: 2481 high: 4791 min/max: 400/4829 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3512 2: 4791 3: 2815
4: 400 5: 400 6: 400 7: 2735 8: 2737 9: 3239 10: 2819 11: 4791 12: 4790
13: 2736 14: 400 15: 2737 16: 400 bogomips: 102212
Device-1: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e1
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2,
DP-3, DP-4, DP-5, DP-6, Writeback-1 bus-ID: 75:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 35.0 C
Device-3: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 3277:0018
class-ID: 0e02
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-2 res: 1707x1067 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.57 6.10.7-zen1-1-zen) device-ID: 1002:1681
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.1-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4050 Laptop GPU driver: nvidia
v: 560.35.03 device-ID: 10de:28e1 surfaces: xcb,xlib,wayland device: 2
v: 24.2.1-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 75:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 75:00.5
bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.10.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0489:e0f6
Local Storage: total: 1.82 TiB used: 39.77 GiB (2.1%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QJXD7 temp: 25.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 39.76 GiB (2.1%)
used: 39.76 GiB (2.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.87 GiB used: 186.2 MiB (1.2%)
System Temperatures: cpu: 43.9 C mobo: 30.0 C gpu: amdgpu temp: 35.0 C
Memory: total: 16 GiB note: est. available: 14.87 GiB used: 7.93 GiB (53.3%)
Processes: 481 Power: uptime: 23h 54m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.9 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1491 libs: 472
tools: gnome-software,octopi,paru Compilers: gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-08-28
Last full system update: 2024-08-30 ↻
Strangely enough, I had Garuda installed on this laptop a few months ago and had none of these issues, and never had to do something like this.
I had reinstalled windows for a short while, then after putting Garuda back onto this it’s starting to do all of this. No idea why haha
Before it works fine OOTB?
BTW, reboot!!!
Yeah, I had installed Garuda back in June. Worked perfectly fine, 0 issues whatsoever. Reinstalled windows in July for a friend to use, put Garuda back on a few days ago and now it’s doing all of this.
Maybe all the changes on KDE are the culpably.
Try from login page X11.
Okay, i’m on X11 now; Updated and rebooted. Should I just test a game now?
Yes, sure, try a game on x11.
As said in my post above, it is something important to test (especially with an Nvidia GPU).
