Hello So I am getting error when trying to use Garuda Welcome and then Garuda Assistant to update my system. But I am getting this outpu when trying to update my systemt.
Warning: Could not start program '/tmp/tmp.QqQv62D8Nj' with arguments ''.
Warning: execve: No such file or directory
garuda-inxiOutput
Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=830a87bb-2001-4f99-9a03-09ce7db83b62 rw rootflags=subvol=@
quiet
cryptdevice=UUID=88e6cf1b-500c-47de-b349-7c1a1a4eb97e:luks-88e6cf1b-500c-47de-b349-7c1a1a4eb97e
root=/dev/mapper/luks-88e6cf1b-500c-47de-b349-7c1a1a4eb97e quiet splash
resume=/dev/mapper/luks-ea315bf9-d399-4603-82f2-6fb363705dd3 loglevel=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B48 v: 1.0
Mobo: Micro-Star model: Z370-A PRO (MS-7B48) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.B0
date: 01/07/2020
Device-1: hidpp_battery_1 model: Logitech Wireless Touch Keyboard K400 Plus
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4167 high: 4403 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4400 2: 4402 3: 3700
4: 4400 5: 3700 6: 4399 7: 4400 8: 4403 9: 3700 10: 3700 11: 4400 12: 4400
bogomips: 88796
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Micro-Star MSI
status: current (as of 2023-03) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 compositors:
1: kwin_x11 2: Tabby driver: X: loaded: nvidia unloaded: modesetting
Screen-1: 0 s-res: 3840x2160 s-dpi: 80 s-size: 1219x686mm (47.99x27.01")
s-diag: 1399mm (55.07")
Monitor-1: DP-2 pos: bottom-l res: 1920x1080 dpi: 82
Monitor-2: DP-4 pos: primary,bottom-r res: 1920x1080 dpi: 82
Monitor-3: HDMI-0 pos: top-right res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-11:19 alternate: snd_soc_avs
chip-ID: 1038:12ad class-ID: 0300 bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 type: USB
API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-2: Broadcom vendor: ASUSTeK driver: brcmfmac v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 14e4:43c3
Device-3: Microsoft Xbox Wireless Adapter for Windows type: USB
driver: xone-dongle bus-ID: 1-3:9 chip-ID: 045e:02fe class-ID: 0000
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-4: vboxnet0 state: down mac: <filter>
Local Storage: total: 5.68 TiB used: 1.33 TiB (23.5%)
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0Gb/s
type: SSD serial: <filter> rev: 37R5 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-1: / raw-size: 188.85 GiB size: 188.85 GiB (100.00%)
used: 119.54 GiB (63.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-88e6cf1b-500c-47de-b349-7c1a1a4eb97e
used: 752 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 188.85 GiB size: 188.85 GiB (100.00%)
ID-4: /var/log raw-size: 188.85 GiB size: 188.85 GiB (100.00%)
ID-5: /var/tmp raw-size: 188.85 GiB size: 188.85 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 23.07 GiB (73.7%)
ID-2: swap-2 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
mapped: luks-ea315bf9-d399-4603-82f2-6fb363705dd3
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 445 Uptime: 9d 6h 15m wakeups: 120 Memory: 31.29 GiB
used: 24.51 GiB (78.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 2278 libs: 582 tools: octopi,paru,yay pm: flatpak pkgs: 0
inxi: 3.3.26
System install date: 2023-03-28
Last full system update: 2023-04-10 ↻
Failed units: systemd-coredump@10-2071607-0.service
