Help to fix xone-dongle
Hello there, i have once again a little newbie question.
Since last week the controller is not connecting to the dongle anymore. from search n stuff i figured it is probably that the xone-dkms got replaced by the xone-dlunqvuist-dkms. Problem now is that if i try to install that with the garuda gamer it prompts the following and quits
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
:: xone-dkms-git-0.3.r94.g6b9d59a-2 and xone-dkms-0.3-4 are in conflict. Remove xone-dkms? [j/N]
Fehler: Nicht auflösbare Paketkonflikte gefunden
Fehler: Vorgang konnte nicht vorbereitet werden (In Konflikt stehende Abhängigkeiten)
Press enter to exit
so im asking for the commands to uninstall the xone-dkms by hand or something ?!
thanks in advance
─wirr@wirr in ~
╰─λ garuda-inxi
Kernel: 6.12.15-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b3328148-480b-42c9-9425-ff822289ea26 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_wayland tools: xscreensaver,xscreensaver-systemd vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3207 date: 02/08/2025
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3006 min/max: 545/5733 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3006 2: 3006 3: 3006
4: 3006 5: 3006 6: 3006 7: 3006 8: 3006 9: 3006 10: 3006 11: 3006 12: 3006
13: 3006 14: 3006 15: 3006 16: 3006 17: 3006 18: 3006 19: 3006 20: 3006
21: 3006 22: 3006 23: 3006 24: 3006 bogomips: 225255
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-2
empty: DP-2, DP-3, DP-4, HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2216
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 50.0 C
Monitor-1: HDMI-A-2 model: HISENSE serial: <filter> built: 2023 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 68 gamma: 1.2
size: 1428x804mm (56.22x31.65") diag: 1639mm (64.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
drv: nvidia device: 1 drv: radeonsi gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.86.16
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 13 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: N/A device-ID: 10de:2216
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 046d:0a66 class-ID: 0300
API: ALSA v: k6.12.15-1-lts status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.2:4
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 5.15 TiB used: 2.82 TiB (54.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
size: 1.75 TiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM15.1 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 57.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD8SBBU240G1122
tech: SSD serial: <filter> fw-rev: 6000 scheme: MBR
used: 103.23 GiB (22.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.51 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 61.8 C mobo: 48.0 C gpu: amdgpu temp: 51.0 C
Memory: total: 32 GiB note: est. available: 30.51 GiB used: 5.86 GiB (19.2%)
Processes: 556 Power: uptime: 6h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1907 libs: 574 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
System install date:     2023-04-15
Last full system update: 2025-02-20
oh darn, if i had waited just 5 more minutes, i had seen this post
:smiley: , just changed to
`sudo pacman -R xone-dkms`
and it worked :sweat_smile:
should i delet the topic?
Your all good homie. Thanks all the same.
No, please do not delete.
Btw: 10 minutes from opening the topic to solving it yourself is not bad.
Unfortunately, you didn’t win any prizes, the record for “Master of Self Solving” is 2 minutes. :smile:
