Help regarding trying to install Garuda on a friend's PC
Hello, a friend of mine is trying to install Garuda Dragonized (Both gaming and non-gaming) on their PC but they’re having trouble with it, their specs are Motherboard: A320M-A Pro max, GPU: 1660 SUPER, CPU: AMD Ryzen 5 3600 4.21 GHz RAM: 16 Gigabytes the first issue they encountered is due to their BIOs, it’s MSI Click BIOS 5, and they tried looking for “Fast boot” option but couldn’t find any even after updating their BIOs to the 06/10/2024 version, as for safe boot they had that disabled, which I suspect is the issue, what happens is that, after trying to boot into the USB bootloader the screen is just black, and after a bit a message appears saying “Grub loading” then continues on a blackscreen, they tried installing Ubuntu and it worked, they tried changing from FAT32 to Ext4, even tried changing both the UEFI and CSM in their BIOs, they tried using 64 gb, 32 gb, 16 gb, 8 gb USB sticks and all lead back to the same issue, they tried with Rufus, Etcher and Ventoy.
Just a note, this isn’t post installation, the bootloader itself doesn’t at all show the installation screen or anything when booting into the USB stick.
Please try again with Ventoy, making sure to use the Grub2 option when promted in the boot process.
Also make sure to verify the checksum of the iso file, after copying it onto the USB.
Maybe you can get it pressing F7 key when in BIOS to switch to “Advanced Mode”.
