Hello everyone, this is my first post here and I want to apologize ahead of time to anyone who gets triggered by me being a forum noob and posting like its facebook lol I get it now and I want to thank everyone who is trying to help
I just installed Garuda for my first linux distro and i have no sound. i installed pulse audio volume control and it shows my sound cards as (unplugged)
im on a galaxy book 2 pro 360
here is the required command text:
root=UUID=d658b71c-eb70-4abc-8b48-0adedd3e6704 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Convertible System: SAMSUNG product: 950QED v: P08AKK
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: SAMSUNG model: NP950QED-KB1US
v: SGLB182A1Z-C01-G002-S0001+10.0.22000 serial: <superuser required>
UEFI: American Megatrends LLC. v: P08AKK.680.220621.SH date: 06/21/2022
ID-1: BAT1 charge: 31.8 Wh (46.9%) condition: 67.8/66.8 Wh (101.4%)
volts: 16.0 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: charging cycles: 11
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x421
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1558 high: 2500 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 974 2: 2500 3: 982 4: 684
5: 766 6: 2500 7: 983 8: 2500 9: 826 10: 671 11: 2500 12: 1092 13: 453
14: 2500 15: 2500 16: 2500 bogomips: 79872
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: Sunplus Innovation 1080p FHD Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 1bcf:2d05 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: gpu: i915 note: X driver n/a display-ID: :0
Monitor-1: eDP-1 model: Samsung 0x4159 built: 2020 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Samsung Co
chip-ID: 8086:51c8 class-ID: 0401
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 953.87 GiB used: 9.48 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ1T0HBLB-00B
lanes: 4 type: SSD serial: <filter> rev: FXM7AK1Q temp: 29.9 C scheme: GPT
used: 9.48 GiB (1.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.24 GiB used: 37.5 MiB (0.2%)
Src: /sys System Temperatures: cpu: 55.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 370 Uptime: 3h 22m wakeups: 9960 Memory: 15.24 GiB
used: 6.53 GiB (42.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1516
libs: 391 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-19
Last full system update: 2022-11-19 β»
Snapshots: Timeshift
