Help Needed with Nvidia Drivers
Hi,
I am currently having an issue with graphics on my desktop running Garuda Dragonized.
PC Spec is a AMD 5900x CPU
NVIDIA 1050 Ti GPU.
I initially was having issues with glitchy screens and when checking Journal Events I could see that Kernel Drivers did not match the installed drivers.
The Kernel driver was 545.29.06 while the installed driver was 550.67
I therefore accessed the Garuda Settings Manager, and opted to Auto Install Open-Source Driver thinking that this would resolve the issue.
Upon reboot, I now have only one monitor working and resolution is at 1024x768.
I tried accessing the Garuda settings manager again and tried to Auto install proprietary drivers again, but following a reboot, this made no difference.
Any assistance with this issue would be greatly appreciated.
Many thanks in advance
My Inxi log
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e339e179-2086-4304-a66f-e9c940454e6b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_wayland vt: 3 dm: SDDM Distro: Garuda base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
UEFI: American Megatrends v: 4702 date: 10/20/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3680 high: 3700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3598 10: 3700 11: 3700
12: 3598 13: 3700 14: 3605 15: 3700 16: 3700 17: 3700 18: 3700 19: 3599
20: 3700 21: 3700 22: 3626 23: 3700 24: 3700 bogomips: 177619
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: N/A
alternate: nouveau non-free: 545.xx+ status: current (as of 2024-02;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:7
chip-ID: 046d:085b class-ID: 0102 serial: <filter>
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 1024x768 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 24.0.3-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.52 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM
17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.1 chip-ID: 10de:0fb9
Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:11b1
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:10 chip-ID: 8087:0029
Local Storage: total: 2.31 TiB used: 31.22 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
model: WD5000BPVT-75HXZT1 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SP0812C
size: 74.56 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: N/A serial: <filter> fw-rev: 0-27 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD3200AVJS-63B6A0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 3A01
ID-6: /dev/sde maj-min: 8:64 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 vendor: Kingston model: DataTraveler 2.0
size: 14.64 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 31.16 GiB (13.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 60.8 MiB (63.3%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-4: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
System Temperatures: cpu: 43.0 C mobo: 32.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 32 GiB available: 31.25 GiB used: 5.34 GiB (17.1%)
Processes: 439 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2258 libs: 615 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-01-31
Last full system update: 2024-03-23
try running sudo pacman -S --needed linux linux-headers nvidia after which , reboot . On boot select advanced options for garuda linux and choose the option which states linux arch 6.8 smthng like dat and then see if it boots successfully without issues.
Thanks for coming back to me. I’ll give that a try and get back to you. :slight_smile:
No change unfortunately, still just 1 monitor at 1024x768 resolution. I did access the advanced settings at the grub screen but there was no entry that stated kernel 6.8.1, just linux-zen. Got a feeling that it’s on currently nomodest for graphics, but I could be wrong
after installing the linux package ? Could you send a photo of the advanced grub menu options please ?
Sure. I will post it via mobile, but will need to pick this back up tomorrow.
okay if this doesn’t work then run sudo pacman -R linux linux-headers nvidia && sudo pacman -S linux-lts linux-lts-headers nvidia-lts reboot and in advanced options choose linux lts if available.
Great! Apparently new users cannot upload photos, so here are the entries:
Garuda Linux, with Linux linux-zen
Garuda Linux, with Linux linux-zen (fallback initramfs)
Garuda Linux, with Linux linux-zen (recovery mode)
Garuda Linux, with Linux linux (fallback initramfs)
Garuda Linux, with Linux linux (recovery mode)
well linux linux is the entry I am talking about , so before running the command I posted above , try booting into linux linux entry.
Ok, so we have 2 screens again… But no greeter yet. Just a cursor on a black screen.
you din’t run the command above , did you ? I mean anyways you are NOT supposed to run it.
No I didn’t run the last CMD, only the prior one you gave me. Worth trying to log in via TTY??
Hmm , just so you know I am a intel igpu guy so I know NOTHING about nvidia . So , all the trials and error commands I will give you are based on wikis and my common linux user sense so sorry if I can’t help you.
Anyways run the prior command and try booting into linux lts entry .
Will try this tomorrow… so to clarify run sudo pacman -S --needed linux linux-headers nvidia then try and login via Linux LTS, right?
Nope , see my 3rd reply.
Got you! Will update again tomorrow. Thanks for your help :slight_smile:
If you want to keep using the Zen kernel, you will need to install the DKMS version of the Nvidia drivers.
sudo pacman -S nvidia-dkms
A lot of folks are reporting issues running a Wayland session on proprietary Nvidia drivers. You may need to set additional kernel parameters (see this post for example), or switch to an X11 session on the login screen before you sign in.
Thank you for the advice, I ran sudo pacman -S nvidia-dkms and that bought back the 2 screens however upon login using Wayland, I just ended up having black background and no dock loading. I have therefore resorted to using X11 at the login screen and now functionality seems to be back to normal.
