Help need for increasing the zram size
Hello Garuda users,
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a526a2d4-154b-4828-bcc8-6b0798ec273d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
Mobo: HP model: 87B2 v: 31.25 serial: <superuser required> UEFI: AMI
v: F.32 date: 10/25/2023
ID-1: BAT0 charge: 37.7 Wh (92.6%) condition: 40.7/40.7 Wh (100.0%)
power: 10.4 W volts: 12.1 min: 11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: discharging cycles: 365
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600109
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2732 high: 3000 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3000 2: 3000
3: 3000 4: 3000 5: 3000 6: 3000 7: 1397 8: 1397 9: 3000 10: 3000 11: 3000
12: 3000 bogomips: 71863
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 46.0 C
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0408:5365
class-ID: 0e02
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.3-zen1-1-zen) device-ID: 1002:1636 memory: 500 MiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1636 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1650 Ti driver: nvidia
v: 545.29.06 device-ID: 10de:1f95 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:b00c
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 1.14 TiB used: 8.05 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 43.9 C scheme: GPT
model: WD10SPSX-60A6WT0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
used: 8.05 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.99 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes: 372 Uptime: 5m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.99 GiB used: 3.26 GiB (21.7%) Init: systemd v: 254
pm: pacman pkgs: 1284 libs: 364 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date:     2023-11-29
Last full system update: 2023-11-29 ↻
So I have followed this guide to increase my zram size What can I do to get rid of swap and use zram only? | I made a mistake during the install - #8 by Cannabis
Here’s my config file,
zram-configuration.conf:
[zram0]
host-memory-limit = none
zram-size = ram * 5
compression-algorithm = zstd
zram-fraction = 1
Zram is set up by default in Garuda Linux. There is no need to take any additional action.
See here, it is showing up as a swap device:
In the thread you linked, the person had set up a second swap device (in addition to the zram) which they wanted to remove. There were some complications with the approach that was chosen and zram needed to be reconfigured.
Yeah I agree that the zram is enabled by default in Garuda Linux but I just want to increase my zram size(by default it’s 15 gb). That’s why I have added zram-size = ram * 5 to my configuration file (/usr/lib/systemd/zram-generator.conf)
You have a total of 16 GB physical RAM installed,
How exactly are your plans to exceed that supposed to work? And why? It’s easy to setup, but not the way you are going about it. See the Arch Wiki.
First I have installed Garuda Linux on my HDD and edited zram configuration and it worked surprisingly. But now I have installed Garuda Linux on SSD and I’m using the same configuration file and it’s not working.
I’m an AOSP developer and 16gb ram is nothing for me to work things out that’s why I’m trying to increase the zram size.
Your use case is your use case. Read the wiki. zram - ArchWiki (archlinux.org) Section 1.1 looks interesting.
I think you are not understanding what zram is. What Bro is trying to explain is that zram, unlike a swap partition or a swap file, uses RAM–not the hard drive. If you want more zram you need to install more RAM.
If you need additional swap beyond what zram is providing you should set up another swap device using your hard drive.
I read somewhere that using a regular swap along zram is not ideal, if I recall correctly it would end up swapping to disk the recent pages and keeping least accessed ones in ram.
I have not experimented with it, but zram should also allow to set up a “backing device” to spill over to disk more efficiently.
Anyone tried that? I’m interested too.
OP may also be interested in trying other compression algorithms, maybe that can squeeze available RAM a little more (at the expense of higher CPU usage).
No, you really can make multipliers, if I read the wiki right. It does have to be setup a bit different from OPs example. But I’m in the partial dark as to which/what ZRAM, ZSWAP, etc. & settings Garuda uses. IIRC, nico has made a change or so since Garuda’s inception.
