Help need cant set my screen refresh to 120hz
on this same pc a had windows running at 120hz but since installing garuda i can only set to 60hz.
same cable, same pc, same same everything, it all supports and should work
Please follow the template and post your garuda-inxi.
We need to see your system info if we are to help.
How can we know the answer if you do not show us what machine you got? Can you ask a mechanic what is wrong with your car not taking your car there?
So please open a terminal and type
then copy and paste the output and edit your first post with this information.
Before you paste this information in your edit window type three times ~ and then press enter, after that paste, your information and then underneath the output you pasted, type again three times an ~ (This assures your output is in the right format for us to read after you commit your edit.
Hopefully we can troubleshoot the trouble you are havging after that.
Have a nice day.
Kernel: 6.17.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=707f693e-9dc7-415f-9242-ba69e2d02599 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop Mobo: Gigabyte model: B85M-Gaming 3 v: x.x
UEFI: American Megatrends v: F1 date: 09/05/2014
Info: model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell
Speed (MHz): avg: 3593 min/max: 800/4000 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3593 2: 3593 3: 3593 4: 3593 5: 3593 6: 3593
7: 3593 8: 3593 bogomips: 57468
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
built: 2013 ports: active: none empty: HDMI-A-4,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 580.105.08 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
HDMI-A-2, HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: crocus
Monitor-1: DP-1 model: LG (GoldStar) TV SSCR2 serial: <filter> built: 2022
res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 61 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: crocus device: 3 drv: swrast gbm: drv: crocus
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 580.105.08
device-ID: 10de:1b80 surfaces: N/A device: 1 type: integrated-gpu
name: Intel HD Graphics 4600 (HSW GT2) driver: mesa intel
v: 25.2.6-arch1.1 device-ID: 8086:0412 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 21.1.4 256 bits) driver: mesa llvmpipe
v: 25.2.6-arch1.1 (LLVM 21.1.4) device-ID: 10005:0000 surfaces: N/A
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.17.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-9:5 chip-ID: 2357:0604
Local Storage: total: 3.64 TiB used: 1.74 TiB (47.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DL003-9VT166
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC32 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
ID-3: /dev/sdc maj-min: 8:32 vendor: Imation model: Apollo M250
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
scheme: MBR
used: 859.12 GiB (92.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 664 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: N/A
Memory: total: 16 GiB available: 15.51 GiB used: 4.69 GiB (30.2%)
Processes: 335 Power: uptime: 57m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2129 libs: 604 tools: octopi,pamac,paru
Compilers: clang: 21.1.5 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish
v: 4.2.0 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2024-07-30
Last full system update: 2025-11-12
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-dkms garuda-hardware-profile-nvidia-closed garuda-hardware-profile-nvidia-prime-closed garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
Failed units:            home-knivesron-games drive.mount
24/25 checks run in 1.81 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Deprecated/Outdated/Removed packages should be removed: steam-native-runtime (fix available)
- Failed systemd services found: home-knivesron-games\x20drive.mount
Thanks
Firstly check if your machine is using the integrated or the proprietary driver, as that is a possible candidate to cause the issue you are having,
in a terminal type ‘nvidia-settings’ and provide us the output.
(nvidia-settings:32235): GLib-GObject-CRITICAL **: 17:56:53.235: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
thank you for the help btw. i appriciate it
Did you just notice this now or how long have you had this issue? Only after updating to
The current NVIDIA drivers have several issues, including the 60 Hz problem you described:
i have had the issue a few months now, i first noticed it when i was messing around with the settings. perhaps the hdr option. however i cant to certain as i dident know what i was doing at the time so cant remember the details.
its not a huge deal for me currently as my computer cant really render any games at 120fps anyway. but when i play gzdoom it would be nice to get the 120
Looks like i will have to wait for nvidia to work or when i upgrade just buy a radeon
