My garuda linux desktop is glitched there is no wallpaper or any icon simply a black screen . Right click also didn't work on desktop . I got this issue few weeks before so i just reinstalled my garuda linux but here i am again with same issue
please post your garuda-inxi thanks and please put more detail here like what desktop you're using
These are black screen topics from this site that I hope help you. https://forum.garudalinux.org/search?q=black%20screen
what desktop do you have downloaded? If your able to get to your terminal put garuda-inxi in there and share the output here please.
Kernel: 5.15.79-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e612cf20-32cc-4a09-8f5b-9b13d0698aca rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: LENOVO product: 90K800CXIN v: ideacentre 510S-07ICB
Mobo: LENOVO model: 3140 v: NOK serial: <superuser required> UEFI: LENOVO
v: M22KT34A date: 05/02/2019
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF0
desc: 1x6 MiB
Speed (MHz): avg: 938 high: 994 min/max: 800/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 951 3: 994 4: 908
bogomips: 28800
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: none empty: DP-1, DP-2, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e91 class-ID: 0380
Device-2: NVIDIA GK208B [GeForce GT 710] vendor: Shenzhen Colorful Yugong
and Development driver: nouveau v: kernel non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 code: GF119/GK208
process: TSMC 28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8
ports: active: VGA-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:128b class-ID: 0300 temp: 34.0 C
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa dri: nouveau,iris
gpu: nouveau display-ID: :0.0 screens: 1
Monitor-1: VGA-1 model: Lenovo LI2215sD serial: <filter> built: 2019
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Shenzhen Colorful Yugong and
Development driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound API: ALSA v: k5.15.79-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
chip-ID: 8086:3166 class-ID: 0280
bus-ID: 1-14:8 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 238.47 GiB used: 12.08 GiB (5.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Geonix model: gold edition SSD DAHUA
type: SSD serial: <filter> rev: 02 scheme: GPT
used: 12.08 GiB (5.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 3.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C pch: 42.0 C mobo: N/A gpu: nouveau
temp: 34.0 C
Processes: 233 Uptime: 1m wakeups: 0 Memory: 3.72 GiB used: 1.16 GiB (31.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1191 libs: 334 tools: pamac,paru
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-18
Last full system update: 2022-11-26
Please, @shashank232p
post terminal input and output as text formatted between three ~ in first and last line.
my terminal text
my terminal text
I move it from #issues-assistance:newbies to Xfce
my terminal text
my terminal text
I've already edited it for you. And there are three ~ meant, not one.
Installing propriearty drivers may help.
sudo pacman -S nvidia-470xx-dkms
Also did you actıally try setting a wallpaper?
error: target not found: nvidia-470xx-dkms~~~
Try
sudo dkms autoinstall
sudo: dkms: command not found
Install it
sudo pacman -Syu dkms
done with installation
and tried command given above not working
Please post
ls /var/lib/mhwd/ids/pci/
amdgpu_exp.ids ati.ids nvidia-470xx.ids
amdgpu.ids nvidia-390xx.ids nvidia.ids
Maybe @Yorper can help. ![]()
thankx to all your team , today a new update come and after that my glitch is fixed
This topic was automatically closed after 7 days. New replies are no longer allowed.
