Help me to switch from radeon to amdgpu
I am new to garuda linux
and i am having these specs
harsh@harsh-vostro3480
OS: Garuda Linux x86_64
Host: Vostro 3480
Kernel: 6.4.9-zen1-1-zen
Uptime: 18 seconds
Battery: 68% [Not charging]
Packages: 1811 (pacman)[stable]
Shell: fish 3.6.1
Terminal: konsole 23.4.3
CPU: Intel(R) Core(TM) i5-8265U (8) @ 3.9 GHz
GPU: Intel UHD Graphics 620
GPU: AMD Radeon R5 M435
Memory: 1.49 GiB / 15.36 GiB (9%)
╭─harsh@harsh in ~
╰─λ lspci -k | grep -A 3 -E "(VGA|3D)"
00:02.0 VGA compatible controller: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] (rev 02)
DeviceName: Onboard - Video
Subsystem: Dell WhiskeyLake-U GT2 [UHD Graphics 620]
Kernel driver in use: i915
╭─harsh@harsh in ~ took 799ms
╰─λ lspci -k | grep -EA3 'VGA|3D|Display'
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Jet PRO [Radeon R5 M230 / R7 M260DX / Radeo
n 520/610 Mobile] (rev c3)
Subsystem: Dell Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520/610 Mobile]
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
╭─harsh@harsh in ~ took 12ms
╰─λ
I have tried these and i am getting Radeon kernel in use instead of amdgpu on ubuntu it was easy by just using grub parameter but on garuda i tried blackisting and also using grub parameter nothing worked please help me to disable Radeon and use AMDGPU my GPU is sea island AMD Radeon 520 and system detects it as AMD r5 m435 please help!!!!!!!!!!!!
Check if this helps, and please always include your garuda-inxi, as required by the template. I assume your installation is new, so you have dracut and don't need the early kms part in the Wiki:
https://wiki.archlinux.org/title/AMDGPU#Load_amdgpu_driver
doesnt work tried it earlier
Please @harsh69
