Okay, so it happened that I was reinstalling Garuda. Nvdec worked before in mpv, but now it doesn't, and I can't for the life of me remember, what I did before to make it work.
vo=gpu and hwdec=nvdec is added to mpv.conf, but not working.
I have found gstreamer-nvidia in the aur, providing nvdec/nvenc, but that fails to build. I think I need help.
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=66e5d40a-2370-44f3-b3b6-ddff5b2046cf rw rootflags=subvol=@
resume=UUID=e5f09ca4-2e13-4405-b97d-9a69816c4515 loglevel=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: bspwm 0.9.10
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO V2
serial: <superuser required> UEFI: American Megatrends LLC. v: F14e
date: 10/14/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3025 high: 3623 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2805 2: 3623
3: 2874 4: 2874 5: 2870 6: 2873 7: 2869 8: 2868 9: 3585 10: 3586 11: 3219
12: 2873 13: 2874 14: 2871 15: 2874 16: 2871 bogomips: 121372
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 07:00.0
chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: picom v: git-c4107
driver: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.6x15.4")
s-diag: 804mm (31.7")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
Device-3: RODE Microphones RØDE NT-USB Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.3:6 chip-ID: 19f7:0015
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: sink type: zfs status: ONLINE level: raidz1 raw: size: 49.1 TiB
free: 37.4 TiB allocated: 11.7 TiB zfs-fs: size: 32.58 TiB free: 24.77 TiB
Components: Online:
1: sda maj-min: 8:0 size: 16.37 TiB
2: sdb maj-min: 8:16 size: 16.37 TiB
3: sdc maj-min: 8:32 size: 16.37 TiB
Local Storage: total: raw: 50.93 TiB usable: 34.4 TiB
used: 7.83 TiB (22.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair
model: Corsair MP600 PRO XT size: 1.82 TiB block-size: physical: 512 B
rev: EIFM31.2 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MG09ACA18TE
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0104 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MG09ACA18TE
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MG09ACA18TE
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 23.79 GiB (1.3%)
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 23.79 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.77 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 69.05 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 47 C
Processes: 463 Uptime: 1h 53m wakeups: 0 Memory: 62.77 GiB
used: 14.06 GiB (22.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1198 lib: 292 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-13
Last full system update: 2022-02-13
