I’m having issues getting HyprIdle to work properly, I have my lockscreen setup but my main issue is that Hyprlock isn’t being recognized by SystemD.
This is the error i get when i run loginctl session-status
╭─sidious@sidious in ~
╰─λ loginctl session-status
Failed to get path for session 'auto': Caller does not belong to any known session and doesn't own any suitable session.
This is the error i get when i try to run loginctl lock-session
╰─λ loginctl lock-session
Failed to issue method call: Unknown object '/org/freedesktop/login1/session/auto'.
This is my HyprIdle config:
general {
lock_cmd = pidof hyprlock || hyprlock
before_sleep_cmd = loginctl lock-session
after_sleep_cmd = hyprctl dispatch dpms on
listener {
timeout = 150
on-timeout = hyprlock
listener {
timeout = 600
on-timeout = hyprctl dispatch dpms off
on-resume = hyprctl dispatch dpms on
I do have hypridle
setup in hyprland.conf
# run hypridle
exec-once = hypridle
When I try to run hypridle from the terminal I get:
[LOG] Registered timeout rule for 150s:
on-timeout: hyprlock
on-resume:
[LOG] Registered timeout rule for 600s:
on-timeout: hyprctl dispatch dpms off
on-resume: hyprctl dispatch dpms on
[LOG] | got iface: wl_seat v9
[LOG] > Bound to wl_seat v9
[LOG] | got iface: wl_data_device_manager v3
[LOG] | got iface: wl_compositor v6
[LOG] | got iface: wl_subcompositor v1
[LOG] | got iface: wl_shm v1
[LOG] | got iface: wp_viewporter v1
[LOG] | got iface: wp_tearing_control_manager_v1 v1
[LOG] | got iface: wp_fractional_scale_manager_v1 v1
[LOG] | got iface: zxdg_output_manager_v1 v3
[LOG] | got iface: wp_cursor_shape_manager_v1 v1
[LOG] | got iface: zwp_idle_inhibit_manager_v1 v1
[LOG] | got iface: zwp_relative_pointer_manager_v1 v1
[LOG] | got iface: zxdg_decoration_manager_v1 v1
[LOG] | got iface: wp_alpha_modifier_v1 v1
[LOG] | got iface: zwlr_gamma_control_manager_v1 v1
[LOG] | got iface: ext_foreign_toplevel_list_v1 v1
[LOG] | got iface: zwp_pointer_gestures_v1 v3
[LOG] | got iface: zwlr_foreign_toplevel_manager_v1 v3
[LOG] | got iface: zwp_keyboard_shortcuts_inhibit_manager_v1 v1
[LOG] | got iface: zwp_text_input_manager_v3 v1
[LOG] | got iface: zwp_pointer_constraints_v1 v1
[LOG] | got iface: zwlr_output_power_manager_v1 v1
[LOG] | got iface: xdg_activation_v1 v1
[LOG] | got iface: ext_idle_notifier_v1 v1
[LOG] > Bound to ext_idle_notifier_v1 v1
[LOG] | got iface: ext_session_lock_manager_v1 v1
[LOG] | got iface: zwp_input_method_manager_v2 v1
[LOG] | got iface: zwp_virtual_keyboard_manager_v1 v1
[LOG] | got iface: zwlr_virtual_pointer_manager_v1 v2
[LOG] | got iface: zwlr_output_manager_v1 v4
[LOG] | got iface: org_kde_kwin_server_decoration_manager v1
[LOG] | got iface: hyprland_focus_grab_manager_v1 v1
[LOG] | got iface: zwp_tablet_manager_v2 v1
[LOG] | got iface: zwlr_layer_shell_v1 v5
[LOG] | got iface: wp_presentation v1
[LOG] | got iface: xdg_wm_base v6
[LOG] | got iface: zwlr_data_control_manager_v1 v2
[LOG] | got iface: zwp_primary_selection_device_manager_v1 v1
[LOG] | got iface: xwayland_shell_v1 v1
[LOG] | got iface: wl_drm v2
[LOG] | got iface: zwp_linux_dmabuf_v1 v5
[LOG] | got iface: hyprland_toplevel_export_manager_v1 v2
[LOG] | got iface: zwp_text_input_manager_v1 v1
[LOG] | got iface: hyprland_global_shortcuts_manager_v1 v1
[LOG] | got iface: zwlr_screencopy_manager_v1 v3
[LOG] | got iface: wp_drm_lease_device_v1 v1
[LOG] | got iface: wl_output v4
[LOG] found 2 rules
[LOG] wayland done, registering dbus
[CRITICAL] Couldn't connect to logind service ([org.freedesktop.login1.NoSessionForPID] Caller does not belong to any known session and doesn't own any suitable session.)
The main issue that critical error at the end
I’ve looked through the journal trying to find anything relevant, please advice, so i can provide any additional information needed.
From what i have deduced from the errors with loginctl
is that the main problem with not having hyprlock trigger through loginctl lock-session
is that for whatever reason the caller isn’t attracted to a session. How do i fix that issue first?
I’ve looked online and have not found much on this issue and have asked a friend that does know a bit more about Linux then I do, and he was unable to figure out the issue.
I am assuming that I need to provide more Configuration documentation but I don’t know what documentation i need to give, so please advice.
Edit 1:
I swapped to another TTY and got this for loginctl session-status
7 - sidious (1000)
Since: Fri 2024-06-14 14:11:07 EDT; 52s ago
State: active
Leader: 2099594 (login)
Seat: seat0; vc3
TTY: tty3
Remote: no
Service: login
Type: tty
Class: user
Idle: no
Unit: session-7.scope
├─2099594 "login -- sidious"
├─2102975 -bash
└─2113834 loginctl session-status
Jun 14 14:11:07 sidious-desktop systemd[1]: Started Session 7 of User sidious.
Jun 14 14:11:07 sidious-desktop login[2099594]: LOGIN ON tty3 BY sidious
Jun 14 14:11:07 sidious-desktop sudo[2103059]: sidious : a password is required ; TTY=tty3 ; PWD=/home/sidious ; USER=root ; COMMAND=/usr/bin/true
Jun 14 14:11:31 sidious-desktop sudo[2108527]: sidious : a password is required ; TTY=tty3 ; PWD=/home/sidious ; USER=root ; COMMAND=/usr/bin/true
Edit 2:
on the other TTY I was advised to try to run hyprland on there, and this is what i got when i started hypridle through the teriminal
[🔴] × hypridle
on-resume:
[LOG] found 2 rules
[LOG] Using dbus path /org/freedesktop/login1/session/_37
[ERR] Failed registering for /org/freedesktop/ScreenSaver, perhaps taken?
err: [org.freedesktop.DBus.Error.FileExists] Failed to request bus name (File exists)
Edit 3: Talking with the folks over at Hyprland and we have determined that sddm isn’t setting up my login session properly. How do I fix that?
I’ve tested loginctl lock-session
on tty3 and it works.
Edit 4:
IMPORTANT QUESTION: Why is there a Garuda-Hyperland
session on sddm
and an hyprland
session on the login screen?
I swapped to the regular hyperland option and i get a session.
Edit 5:
rebooted and even the hypridle session is broken.
got the same error i got when i tried to run hyperidle again but without the hyprland session on tty3
Edit 6:
I’ve tried different DMs, lightDM
, gdm
, and litterally no dm, still not getting a session attached when i login.
When i have been able to get a login session, i’ve been able to run the btrfs manager that doesn’t work normally.
Edit 7:
I asked chatGPT and it’s telling me that it might be an issue with PAM…
where do i need to start to trouble shoot that?
Edit 8: more troubleshooting
While i can’t swap TTY normally, using chvt
does work only with sudo when in hyprland. I was able to login on a separate session and get a session id to be recognized, but when i started hyprland the session was no longer recognized.
I feel like i’ve narrowed down the issue to something… i just don’t know what’s wrong with the configuration.
Edit 9: in response to @veitw
here is the garuda-inxi
Kernel: 6.9.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=3bb756bd-9a7b-4fd9-9ce8-e85ddd460bda rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: Hyprland v: 0.41.0 with: waybar tools: avail: hyprlock,swayidle
vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Garuda
Type: Desktop Mobo: NZXT model: N7 B550 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: P2.80
date: 06/07/2023
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3860 high: 4766 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 4766 7: 3800 8: 3800 9: 3808 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121371
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,HDMI-A-1 empty: DP-3,Writeback-1 bus-ID: 09:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: Elgato Systems GmbH Facecam driver: hid-generic,usbhid,uvcvideo
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2
chip-ID: 0fd9:0078 class-ID: 0300 serial: <filter>
compositor: Hyprland v: 0.41.0 driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 8320x3240 display-ID: 1
Monitor-1: DP-1 pos: primary,top-left model: Gigabyte AORUS FO48U
serial: <filter> built: 2021 res: 3840x2160 hz: 120 dpi: 140 gamma: 1.2
scale: 1 size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: max: 3840x2160 min: 640x480
Monitor-2: DP-2 pos: top-right model: Acer EB243YU serial: <filter>
built: 2018 res: 2560x1440 hz: 75 dpi: 123 gamma: 1.2 scale: 1
max: 2560x1440 min: 720x400
Monitor-3: HDMI-A-1 pos: bottom-c model: Cintiq 16 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 scale: 1
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.4-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab30
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Elgato Systems GmbH Wave XLR driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0fd9:007d
API: ALSA v: k6.9.4-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:12 chip-ID: 8087:0032
Local Storage: total: 9.1 TiB used: 132.65 GiB (1.4%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Seagate
model: WDS200T3X0C-00SJG0 size: 1.82 TiB block-size: physical: 512 B
fw-rev: 102430WD temp: 42.9 C scheme: GPT
model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 411.49 GiB size: 411.49 GiB (100.00%)
used: 132.63 GiB (32.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.4 MiB (28.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 411.49 GiB size: 411.49 GiB (100.00%)
ID-4: /var/log raw-size: 411.49 GiB size: 411.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 411.49 GiB size: 411.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.72 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.5 C mobo: 36.8 C gpu: amdgpu temp: 49.0 C
mem: 65.0 C
Fan Speeds (rpm): fan-2: 0 fan-3: 680 fan-4: 0 fan-5: 2177 fan-6: 679
gpu: amdgpu fan: 0
Memory: total: 64 GiB note: est. available: 62.73 GiB used: 7.06 GiB (11.3%)
Processes: 378 Power: uptime: 2h 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1839 libs: 546 tools: pacseek,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.34
System install date: 2024-06-02
Last full system update: 2024-06-14
Edit 10: reinstalled swaylock… don’t know why that might be needed but seems to have given me a session… i’ll update tomarow morning, after a reboot, for now beds.
Edit 10.2:
noticed something i’ve been logging in and logging out several time to deal with an issue with brave not responding after turning off the main monitor… I wonder if the repeated login and logouts just somehow granted a session…
I still have no idea what the issue might be.
